Since my 'new to me' '96 Legacy L - EJ22 - is very similar to the 1st Gen, hopefully some Gear Heads can chime in.
EDIT: Filled in what I found w/this LINK w/CRs. Includes HG thickness.
Looking for Compression Ratio for the following setups:
- Thin (0.56 mm) vs. Thick (1.37 mm) HG CR's added
EJ257 block* + EJ22T heads + STi HG = 9.6 / 9.0
EJ257+ '96 EJ25D (HLA) + STi HG = 8.9/ 8.3 (estimated as '96 was 9.5:1 vs. '97-'99 9.7:1 STOCK CR)
>>>>>>>>>>>>>>>>>>>>>>>8.5 estimate w/comparable EJ20H heads (DOHC HLA, stock 2.0 HG)
EJ257 + '91 EJ22e heads + STi HG = 9.6 / 9.0 (estimated based on EJ22T head CR)
I DO NOT WANT TO DEAL WITH EM - No Wiring, thanks. Yes, I'd like to run 5 PSI w/a VF11 on the 1st setup, since it's already plumbed. But not sure I want to deal w/all the extra work....and potential for more issues.
*Actually an '09 EJ255, but has new STi pistons, so w/STi heads stock CR is 8.2:1.
Notes from HERE:
I hate to give up that much CR, but also don't want to spend 2X on getting too thin of a HG.Use the 11044AA610 gaskets. Do NOT use the 642/670/770 gaskets as the pistons will hit the cylinder head at TDC.
