4.44 and rear diff swap
Posted: Thu Aug 13, 2015 4:15 pm
My wrx 2.0 , upgraded 4eat and 4.44 swap almost complete, couple things I'm up against on the rear diff swap:
outer cv axle stubs are seized in the hubs. and by seized I mean, I'll mushroom them trying to get them out... I need the different style rear cv with the stubs for the newer diff. Can I just swap the inner stub housing cups, new new boots and grease and keep my original shafts and outer joints? or retain my stock outers , just swap on the newer style shafts withthe stub inner joints?
and how should the pinion flange be swapped? are they torued or crush collar type? I come from a land of truck rear diffs, these are new to me!
