Hello everyone, i just picked up a 90 legacy with the ej20g engine in it, it is in need of injectors, im looking at some online but the guy isnt sure if they will fit my car, so before i order them, do i need the 440cc greytop side feed injectors or he mentioned a red top side feed version?
Thank You,
Nick.
ej20g help
ej20g help
Re: ej20g injectors??
You want grey top 440s.
thank you! i got them on order now, hopefully the car will be up and running soon
Re: ej20g help
I didn't want to keep making posts, so i figured i would just reuse this post for my questions, hopefully that is alright.
I am missing a few bolts for the intercooler and the reservoir. they are circled in red in the picture. Does anyone know the thread pitch and size of said bolts i could order from lordco? or a vehicle that i could take them from in a wreckers? i imagine the reservoir bolts are the same for all legacies, its the intercooler bolts that i am mostly wondering about.
Thank You,
Nick.
Thank You,
Nick.
- Winestone Cowboy
Re: ej20g help
The resivior one are the standard 10mm head one that almost all imports use. Just find some off a wrecked one with the right length and your good. The intercooler might be a 12mm head bolt, but with out seeing it I couldn't tell. But looks like a long 10mm bolt like off an air box or something. They usually have a bigger washer but, trial and error buddy, you'll get it
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
