Horn Problems
Posted: Mon Dec 21, 2015 5:07 pm
Hi,
A few month ago someone broke into my car, and tried to steal the stereo. They broke most of the plastic dash around the stereo, and pulled on some wiring.
Since, the break in . The Horn will only work if the Steering wheel is turned 90 degrees in either direction.
If steering wheel is in normal straight position, horn doesn't work. If steering wheel is turned or upside down, horn works fine.
I'm assuming the contacts for the horn in the steering wheel must damaged or dirty, but thought I would ask before I start trying to take it apart.
Thanks!
Lou
Thanks!
Lou
