Boost Control
Posted: Sun May 20, 2001 8:18 pm
Hi,
Sorry I know this subject has been thrashed out overtime here but I
just want to clear a few things up for myself. (must be a little
slow!?)
Anyway Installed my boost guage over the weekend, working well happy
with that.
Now I want to increase the boost a little as well. I've hunted out
and found a couple of good articles, the best appearing to be on
autospeed.com as to the Audi DIY boost control.
So just to be sure I have the application correct for the RS, I
wanted to clarify things. OK I would want to T the bleed valve into
the same line as the boost guage is T'ed off from. This is the line
that runs from the Manifold and I belive it goes to the boost control
solinoid?. I've seen mixed application some people have run this line
straight from the minifold to the turbo and the bleed valve used and
totally bypassing the solinoid, just capping its end. Which would
suit best?
Next I'd want to T a pressure relief valve into the line that runs
from the boost control solinoid to the wastegate.
Hope this is correct.
Last question is the conversion of 1 bar to PSI? I've heard the MAX
boost I'd want to run is 13psi, my guage is in Bar, and I've heard
mixed things as to the conversion from 1B=14.5psi to 16psi. any
comments would be great.
Thanks again.
Quin
slow!?)
with that.
suit best?
Thanks again.
Quin
