91 SS 5-speed
Posted: Tue Apr 26, 2016 6:52 pm
Have an original 5mt from a 91 SS. This has extremely tall gears, letting you do 78mph at 3k RPM. 215k miles. 1st gear whines a tad, and when the gear oil is cold, to grab reverse you have to put it in 3rd then reverse. Both of these are consistant with my last SS trans. The tranny shifts smoothly between gears.
I modified the bellhousing to fit a 6 speed clutch setup, so you could run a 91-94 SS, 02-05 WRX or 04+ STI clutch kit.
$250 obo. I also have a 91 VLSD rear diff, though someone has dibs on it. Ill post up here if that changes. For the next couple weeks you can drive it in my car before i pull it
