Full tune-up, still a little rough. CEL's cleared. '90 N/A
Posted: Fri May 20, 2016 2:57 am
So I could use some advice... There are ZERO shops in Cleveland that will even touch this thing, and even my mechanic friends are lost. So thanks in advance to anyone who gives this some thought, Also, it's an automatic.
My car has always had a few CELs, but only while warming up... Once up to temp it was fine. Coolant temp sensor and MAF were the codes.
Few weeks ago, it started stuttering HARD and was dumping gas out the exhaust. It was a bad injector. So I replaced it.
I cleared the codes , but then got a bunch more... IACV, MAF, CTS, and Knock sensor.
I pulled the IACV, cleaned it (althought it wasn't bad) and I'm pretty sure I returned the motor to near stock position.
After replacing the IACV it was idling at 3K!!!
Here's where you're all going to get mad at me... I dialed back the throttle stop screw. YEP. OOPS.
I then replaced it to where it was - roughly, and discovered that the idle condition was due to the PCV connector being cracked - bad vacuum leak. Got one from the dealer along with a new PCV valve, and the idle dropped back down.
So at this point, the idle is kind of normal, but still hunting all over the place, and stalling. MAF code.
A fresh from pull-a-part MAF cleared up the wandering idle and really stabilized it actually.
However, at this point, I got a solid CEL for the coolant temp sensor, so I replaced it, and FINALLY, I have NO FAULT CODES
Replaced plugs too with the recommended NGKs - gapped appropriately.
Here's the issue. Everything seems clear for the most part. The idle is stabilized, and I get no stumbling on acceleration.
It just runs a little rough. Idle is stable, but just a little spitty? terrible description, I know... but the car used to run soo smooth.
Do I double check the position of the IAC motor?
Do I turn the throttle body stop screw in a few turns? (noting where it is currently)
Do I do either of these while cold or at operating temp?
Maybe I have a failing piston ring in the cylinder that had the bad injector? Maybe it's the autozone injector?
Test compression?
As always, this car starts quicker than any car I've ever owned, just runs kind of rough now.
I'm so damn close, but it's just not satisfactory.
Any thoughts are greatly appreciated. Hopefully I provided enough info.
Test compression?
