WTB - Rear Driver Side Door - MICA RUBY - 947
Posted: Fri Jul 15, 2016 3:20 am
by Brunt
I know it's a long shot, but thought it'd be worth throwing out there...
Looking for a back left door for my '92 Touring Wagon.
Color Code 947 - MICA RUBY
Other doors will be considered since I will likely be doing a bit painting at some point.
Available for trade are parts from a '94 LS wagon (trim color - tan 440, exterior color - green 433 Spruce Pearl), including hood and front right door. I also have some Turbo parts available such as cross-member, radiator, temperamental wiring harness, well used front seats.
I'm located in Olympia / Seattle area, will road trip for the ideal door. No window or door card necessary.
I was mistakenly looking for a winestone door in an earlier thread, apparently I have an uncommon color for a'92 USDM Legacy.
Re: WTB - Rear Driver Side Door - MICA RUBY - 947
Posted: Fri Jul 15, 2016 5:37 pm
by Alphius
As far as I know, you can use any 90-94 door. That broadens your search a bit since Mica Ruby was available in 90-91 and far more common. You can use a sedan door as well as long as you put your wagon glass in it.
Posted: Fri Jul 15, 2016 6:11 pm
by Alphius
Ha, didn't even notice I replied to your other thread with basically the same info. Anyway, if you want to sell that crossmember for cold, hard cash, I'd definitely pick it up.
Posted: Sun Jul 17, 2016 7:37 pm
by Soobster
I've got a silver color rear driver side door from a 91 sedan that might work for you. It's in Portland, OR so not much of a drive.
https://goo.gl/photos/HwGqGWMPpcBVgdHQ9
https://goo.gl/photos/uUZ65HyScuBmCQCN8
Name your price.
Posted: Thu Jul 21, 2016 4:35 am
by Brunt
Thanks again, Alphius.
You're first on the list for the crossmember if it doesn't get traded.
Maybe that will entice you to help me locate a Mica Ruby door ;)
Thanks for the offer, Soobster.
I'm going to look for a Mica Ruby door for a bit longer, I'm checking out a potential match this weekend.
I'll keep you posted if I can't find one.
Posted: Thu Jul 21, 2016 2:46 pm
by Alphius
In reference to another thread of yours, I do trade parts for A/C work. :lol:
Posted: Thu Aug 11, 2016 8:36 pm
by Brunt
I picked up a matching door from a 1990 L wagon at the South Portland Pick 'n' Pull last weekend.
Unfortunately, the clear coat on the exterior is toast.
I'm already planning to repaint my hood for the same reason, so it fits my needs, but it'll probably be a while before I get around to it.
So, unless someone turns up with a match in better shape before I start painting, my search is complete.
