I had a complete running ss donor car that was hit in the front corner,
Car was gunmetal grey, 133k ORIGINAL miles
I swapped everything you can think of, heres the list:
Gas tank and pump, full unit and harness to pump relay
Rear knuckles, control arms, cv's and 3.90 vlsd
Driveshaft and 4eat transmission, trans mount, diff mount, sway bar, links, calipers rotors pads and e brake.
Full rear crossmember
Front crossmember, steering rack, knuckles, cv's, control arm
All 4 struts/springs-KYB Gr2's in rear
Entire harness, ecu and trans unit
Entire dash and all accessories
Heater core and everything behind dash
Full interior, grey alacantara, all three seats, seat belt motors
All 4 doors
Basically everything.
Swap was done and completed and i decided i wanted a different project. Such is life. I sold the short block so thats gone and id like to keep all the motor bits. If youre looking for a true rolling shell ready for a transplant this is it! Body is very straight, it will register as a 1990 legacy sedan l, but it is an ss in disguise. Im asking $600 picked up near boise idaho.
All the hard work has been done for you, just buy a motor and voila!
