Will WRX seats bolt directly into first gen legacy?
Posted: Wed Jan 04, 2017 2:04 am
by WRXish
I have a set of 2009 WRX seats coming for my first gen legacy, are these a direct bolt in or will I have to make mods to make them fit?
Re: Will WRX seats bolt directly into first gen legacy?
Posted: Wed Jan 04, 2017 6:42 am
by Pntaste4evr99
A little mod on the back mounting holes/brackets. At least with 06 STI seats I put in mine I have to mod just the rears.
Posted: Sat Jan 14, 2017 3:35 pm
by WRXish
Thanks for that guys, however the mod to the rear bracket next to transmission tunnel is a serious mod....gonna have to have something welded on there to bolt that corner down or drill a new hole in the floorpan. That hole doesnt even come close to being useable as is. Oh well, that dreaded word comes into play....fabrication!!! argh!
Posted: Sat Jan 14, 2017 7:00 pm
by Alphius
For future reference, 02-07 WRX seats should just bolt right in, but when they went to the new body in 08 they changed the rear seat mounting quite a bit as you found out.
Posted: Tue Mar 13, 2018 12:42 am
by Omega79
Alphius wrote:For future reference, 02-07 WRX seats should just bolt right in, but when they went to the new body in 08 they changed the rear seat mounting quite a bit as you found out.
To add to this in case someone else stumbles in here, the seats will ride a little higher than stock. If you're pretty tall it could be an issue. Average height it's not a big deal, just different.
