vacuum hose reference for EJ20G?
In the process of doing ej20g heads and intake manifold on my 22t. Could somebody please tell me where the 3 little vacuum ports on top of the manifold go? Also, if somebody had a full diagram that would be awesome as well. Tried searching, no luck. Thanks in advance
Re: vacuum hose reference for EJ20G?
The fat one on the passenger side goes to the BPV.
The middle one goes to the pressure exchange solenoid, though I don't remember if I used a reducer or not.
The driver side one goes to a fuel hard line under the manifold, which eventually transitions back to hose going to the fuel pressure regulator.
Here on the right side of the pic, you can see where the driver side port goes to.
https://goo.gl/photos/ApY8p2Nif5MrCYoL9
thank you mike!
