Rebuild in 2017
Posted: Sun Mar 12, 2017 5:42 am
by Soobster
I need to rebuild my EJ22T shortblock and I wanted to get some opinions. I want to rebuild for reliability. The engine had 250k miles when pulled. I'm going to bore it out 0.04 because I have to overbore for the Wiseco pistons anyway. I'm not going to run high boost and the extra displacement should be good for low end. Oil jet had fallen out and been damaged, but I found a replacement.
--Crank
Hopefully reuse existing. Machinist recommended against touching it.
--Pistons & Rings
Wiseco looks like the only option. I understand that these will up the compression ratio. Anything to worry about there? Still non-interference right?
--Head Gasket
OEM that comes with engine gasket set.
--Rods
I'm thinking I should buy new rods due to the engine's age and mileage. Looks like a set of Manley rods (14024-4) are $352 online? Cheaper options? Does anyone have the part number for a 130.5mm STI rod? Machinist recommended using upgraded ARP rod bolts.
--Heads
Hopefully as little as possible. Prep them for gasket. My machinist recommend gasket matching them for better flow. May have him do that depending on his bid. Worth doing anything else?
--Bearings
King Bearings were recommended by the machinist. Not that expensive.
--Bolts
The OEM head bolts are stretch bolts right? How about the case bolts? I'm thinking that I'll replace with OEM as the ARP kits add another $400 to the build
Anything else I need to consider?
Re: Rebuild in 2017
Posted: Sun Mar 12, 2017 6:22 am
by jamal
JE makes 2.2 pistons as well. I am not clear if they are the new strutted FSR design though (which are really great). Edit: not
Looks like cometic still makes a 22t headgasket. People seem to like the OEM ones though. There is the original 22t graphite design as well as the newer MLS part for the later 2.2.
When it comes to rods bolts, if you just add ARPs with a higher torque setting, the journal often ends up out of round. So a set of rods that actually comes with arp2000s would be the best bet.
Case bolts are the same deal- if you put in ARPs the main journals end up out of round. So stick with OEM case bolts torqued to oem spec. You can re-use them, but if they are very corroded some new ones would be a good idea.
Head bolts can also be re-used if they are in good condition, but getting some ARP studs would be worthwhile. E- the sohc head bolts are different but arp makes a set.
If you are interested I can send you a quote for any/all of the parts mentioned. I can usually be pretty competitive.
Re: Rebuild in 2017
Posted: Sun Mar 12, 2017 7:01 am
by zeke
Sohc head bolts are shorter so if you plan on not reusing yours keep that in mind
Re: Rebuild in 2017
Posted: Sun Mar 12, 2017 7:26 am
by zeke
Just my 2 cents about your heads if you are already planning on getting new pistons I would ditch your sohc heads if its in your budget I saw someone recently in the parts shed selling some heads and manifold
http://bbs.legacycentral.org/viewtopic.php?f=15&t=55901
Re: Rebuild in 2017
Posted: Sun Mar 12, 2017 7:35 am
by Soobster
I may do that down the road. For now, it's just too much additional expense. Engine is going into a Vanagon with a SubaruGears WRX transmission.
Re: Rebuild in 2017
Posted: Sun Mar 12, 2017 8:04 am
by zeke
If you do need a new crank rockauto.com has 1 left in stock for 248 plus shipping and it comes with matched king bearings I just had to buy one for my 91 ss
Re: Rebuild in 2017
Posted: Mon Mar 13, 2017 6:57 am
by zeke
I just realised I measured the block bolts vs the head bolts so dont quote me on the length just yet I will measure the correct bolts and see if they are the same length tomorrow
Re: Rebuild in 2017
Posted: Mon Mar 13, 2017 2:38 pm
by 86BRATMAN
sohc head bolts are longer than dohc
Sent from my 0PJA2 using Tapatalk
Re: Rebuild in 2017
Posted: Mon Mar 13, 2017 6:48 pm
by jamal
And ARP does make an SOHC set of head studs. On the website it does say 99+ only, but I am reading they fit the older engines just fine. There are a number of people around here that have used them.
Case bolts should all be the same.
Re: Rebuild in 2017
Posted: Tue Mar 14, 2017 6:02 pm
Yeah, I used the head studs on my motor rebuild. You can see pictures/part number here.
https://main.experiencetherave.com/suba ... eadwork/09
Re: Rebuild in 2017
Posted: Fri Mar 24, 2017 11:10 pm
by Soobster
Forged internals parts list for posterity. Ended up going with the 0.02" oversized pistons per machinist recommendation. Stock crank was fine so it will be reused. Also going to reuse the head bolts and a few of the case bolts. The internal case bolts were fairly corroded, so those will be replaced. Again, the aim here is to rebuild for longevity, smooth idle and maintaining non-interference configuration.
OEM Gasket Kit - 10105AA052
OEM Oil Jets - 15036AA010
OEM Oil Jet Washers - 803905020
Wiseco 0.02 Oversize Pistons - K601M975
Manley Connecting Rods - 14024-4
King XP Main Bearings - MB5220XP
King Rod Bearings - CR4125XPG
OEM Case Bolts (10x158x30) - 800210990
Re: Rebuild in 2017
Posted: Sat Mar 25, 2017 7:25 am
by Alphius
Were you able to get the OEM oil jets? They've been NLA and out of stock for a while now I thought.
Re: Rebuild in 2017
Posted: Sat Mar 25, 2017 7:39 am
by Soobster
Re: Rebuild in 2017
Posted: Sat Mar 25, 2017 8:10 am
by mike-tracy
Interesting. Between several board members we bought their remaining stock last year. That's neat that somewhere, somehow they have sourced some more.
Re: Rebuild in 2017
Posted: Sat Mar 25, 2017 2:20 pm
by cj91legss
I just used a new set in my build!
Yeah I think I bought mine when they had 10 or less in stock.
Re: Rebuild in 2017
Posted: Sun Mar 26, 2017 2:04 am
by Alphius
I've purchased some hard to find items there before. That's awesome if they have more oil squirters. They were showing zero available last year.
Re: Rebuild in 2017
Posted: Mon Mar 27, 2017 5:55 pm
Have you gotten the oil squirters yet and have them in hand?
Re: Rebuild in 2017
Posted: Mon Mar 27, 2017 6:04 pm
by Soobster
Yes. Ordered eight of them. They arrived in about a week following placing the order.
Re: Rebuild in 2017
Posted: Mon Mar 27, 2017 6:11 pm
Good to hear!
Re: Rebuild in 2017
Posted: Tue Mar 28, 2017 9:04 pm
by 86BRATMAN
The squirters are now showing not available on partsouq.
