which header
__TT__
which header
Post by __TT__ »
So looking for a bit of an upgrade to some motor parts while its out.
I have a 22t with 98 2.5gt n/a dohc heads. I can't remember which stock headers I've been using.
I'm thinking any 02-05 wrx aftermarket heads right?
i should also add I'm going to a td05
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: which header
I suggest sticking with the stock exhaust manifolds since they retain heat better. Some of the cars got more "equal length" type collectors. The newer WRX's may have a similar design/setup. This is what I am using.
https://main.experiencetherave.com/suba ... tmanifold/
Pntaste4evr99
Winestone Cowboy
Re: which header
Post by Pntaste4evr99 »
I'm running a Tomei wrx UEL and love it. Might lose heat to stock manifold, but does pull better in mid to upper rpm.
Just my two cents.
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
