ORIGINAL AD:
One engine partly disassembled, the second in the shell. Has one turbo ECU. YOU HAVE TO TAKE THE WHOLE CAR. Will need to be towed. Beverly, Massachusetts.
What else you get:
Duchess, a 1990 wagon, FWD 5-speed. Has turbo block hooked up N/A (ran fine until I swapped to turbo crossmember and never changed the exhaust). Front end was redone before parked about 11 years ago. Has Forester flat 5-spoke 16" wheels, Hella 90mm projector lights, aluminum front control arms, WRX front brakes, aluminum fender braces, Aftermarket steering wheel and adapter, adjustable rear strut bar, blue interior—most of which is in good shape. Shell rusted while in storage and I'm just not going to have the money to do it right (so I'd rather move on to build something of my own design, be it car or boat). About 270k miles, if that matters. A copy of Midnight in a Perfect World novel that features a more idealized version of this car.
When it last saw daylight:
How it has looked:
Projector lights:
