Ej22E to EJ20G Swap
Posted: Thu Jun 08, 2017 3:44 am
by Ty92leg
Hey guys, I have a 92 wagon with the ej22e, 5mt and I think its time for a new engine.. I have been doing some research about possible swaps. I see a lot of ej22t to ej20g swap info and "guides," but I am not familiar with the legacy ss. Is the swap similar or should I go with a different rout? Thanks for any advice in advance
Re: Ej22E to EJ20G Swap
Posted: Mon Jun 12, 2017 5:18 pm
Welcome to the BBS.
The swap should be similar. There will be little differences and things that need to be done, but I can't think of any show stoppers. The main difference will be the ignition and having to rewire things for coil on plug vs. wasted spark.
Posted: Fri Jun 16, 2017 4:46 pm
by Ty92leg
Okay great! That shouldn't be too difficult. Thank you for the info. If I do find myself stuck somewhere I know where to ask.
Posted: Fri Jun 16, 2017 9:34 pm
by nortonjefferson
Dont forget to acquire the turbo related sensors! (map, pressure exchange etc). If you plan on putting a different turbo specific transmission in, you will more than likely also have to go to a hydraulically actuated clutch. Doing this same thing as we speak, just a 22t instead of a 20g. Good luck!!
Posted: Sun Jun 18, 2017 10:10 pm
by PhyrraM
Don't forget the front crossmember.
Sent from my SM-N900V using Tapatalk
Posted: Mon Jun 19, 2017 4:37 am
by Pntaste4evr99
Don't forget the turbo lol
