Camshaft quality control, need some second opinions!
Posted: Mon Oct 23, 2017 2:23 am
Hey BBS,
I recently had some Cam's sent out to Kelford Cams New Zealand to be hard face welded to New specs.
I received the finished product back and wasn't exactly happy with what I was seeing. I've never had cams hard face welded before so I wasn't exactly sure what to expect. What I assumed is that I would receive cams back that looked to be OEM quality, that it would be difficult to see any work done other than a larger profile.
I tried referencing back to an older post from rallyak, he had received cams from Delta that where of poor quality. Unfortunately all the images in that post are broken, no thanks to photofucket.
I do understand the difficulty that comes with this kind of job, particularly the impurities of the existing metal and porosity. What I'm asking is, if this is normal quality of a hard face welding job, or is this not normal and poor quality.
Maybe some other members can chime in that have experience in this field.
As always, thanks for your input!
