window molding removal
208ss
Post by 208ss »
any one know how to remove the metal part above the door windows? going to repaint my car and need to remove them. i have the rear quarter window trim removed already.
1991 subaru legacy sport sedan
Re: window molding removal
I believe you need to remove the rubber weather stripping and that will expose screws used to remove that trim.
Legacy777 wrote:I believe you need to remove the rubber weather stripping and that will expose screws used to remove that trim.
This is correct.
