Z4 ECU on a 92 GT
Posted: Wed Oct 31, 2018 2:51 pm
by JimBos Legacy
Anybody running the Z4 on the 92 GT? Also I was wonder what the stock ecu on the GTs were, from the research I’ve dont it’s the H7 but I could be wrong. Thanks guys
Re: Z4 ECU on a 92 GT
Posted: Wed Oct 31, 2018 3:07 pm
by mike-tracy
You might want to ask on dirtyolbc or the liberty rs forums for any specific Q's.
I have ran the z4 ecu on a full ej20g before I got my robtune, ran great with the USDM boost control solenoid and sensors. I was running the td05 & gray 440cc injectors that the ecu is looking for.
Posted: Wed Oct 31, 2018 3:32 pm
by JimBos Legacy
mike-tracy wrote:You might want to ask on dirtyolbc or the liberty rs forums for any specific Q's.
Mines an AWIC ej20g so I wasn’t sure if the ecu is okay with that, I’m also running the TD05 but I believe I still have the stock 380cc injectors
Posted: Wed Oct 31, 2018 4:57 pm
by mike-tracy
The difference is the legacy ej20g ecu controls the speed of the pump. I read on the bbs that without the ecu control, the pump still runs, but at full speed.
Posted: Thu Nov 01, 2018 7:37 pm
by ride_child
i ran a z4 on a 91 ss... i had a td05 and 440 injectors. what do you need to know?
Posted: Thu Nov 01, 2018 9:13 pm
by JimBos Legacy
ride_child wrote:i ran a z4 on a 91 ss... i had a td05 and 440 injectors. what do you need to know?
Like Mike was saying about the AWIC pump, does the ECU still work with the AWIC? Also I believe my injectors are the 380cc grey tops, but if someone could confirm that for me that’d be nice
Posted: Fri Nov 02, 2018 12:08 am
by mike-tracy
They measure all the injectors at a lower PSI over there. So their 380cc graytops come out to 440cc injectors using our testing.
Same thing with the ej20k yellow tops, those measure out to 440cc there, and 480cc here.
Posted: Fri Nov 02, 2018 4:53 am
by JimBos Legacy
mike-tracy wrote:They measure all the injectors at a lower PSI over there. So their 380cc graytops come out to 440cc injectors using our testing.
Interesting, thanks for that info
Posted: Sat Nov 03, 2018 10:35 pm
by ride_child
sorry, im not able to offer any info on the awic operation, i had a fxt tmic on the car when i ran the z4.
