OBD read Error
Posted: Mon Jan 14, 2019 3:37 am
I just did a engine swap and went to see if i could read the check engine light and i just simply get a error on the code read literally saying error and that's it. The light came on with in the first 40 miles. I am not totally sure we're to start looking to see what is the problem. Any thoughts on this should be great the car seems to run very well and i have not noticed any sort of actual problem with the way the car runs. This is a 2001 Subaru out back 2.5l engine. I changed it the engine and did not swap over the old intake on to this knew engine.
