car wont start, error code help
Posted: Mon Feb 17, 2003 11:16 pm
by EJ20impreza
So early today i got out and start my car and move it so i can shovel some of the 2+ feet of snow around it. Everything works fine.
A couple hours later I try to start it and it wont start. It started once for a couple seconds, then died. Now it cranks but wont start. I'm pretty sure its not a fuel problem. Im getting error code 55 but the list i have doesnt have that number listed.
Does anybody know what the error code 55 is for OBD-I subarus?
thanks
Posted: Tue Feb 18, 2003 5:34 am
by entirelyturbo
There is no code 55, Legacy777's site doesn't have one and neither does my Haynes manual, try double-checking the code...
Posted: Tue Feb 18, 2003 6:31 am
My factory service manual doesn't list a code 55 either, but all of the references we've mentioned are for US model cars, none if which have an EJ20.
Posted: Tue Feb 18, 2003 6:54 am
by EJ20impreza
Wow actually i triple checked the code. What in the world is going on...? I'll look again in the morning.
Actually im using the EJ18 ecu, so i would think it uses the standard OBD-I that most US subarus use. All the other codes i've seen have been on Legacy777's site.
Posted: Tue Feb 18, 2003 2:52 pm
Clear the codes......or better yet, connect the green & black connectors for the d-check mode and see what happens......if it detects a fault some where.
Posted: Tue Feb 18, 2003 9:25 pm
This is probably no help at all, but the guide at
http://www.ultimatesubaru.net/Manual/mi ... codes.html says that on some Subaru engines, error code 55 meant a problem with the "
"EGR Temperature Sensor or Circuit." The same section of the chart includes codes relevant to Imprezas, so maybe an EJ18 ECU uses that code too.
Posted: Wed Feb 19, 2003 3:05 am
by EJ20impreza
Thanks for sharing that! It really was code 55. But I dont know if that really was the problem though. I cleaned up the spark plugs and reset the ECU and it starts and runs better. The plugs were pretty fouled. Thanks again!
Noah
