I have a 1991 Subaru legacy sport auto. My question
has to do with starting the vehicle. Some times when I
start it. Usually when it has sat over night or for
several hours when I turn the key it starts almost
instantly probably within 1 sec. BUT some times it
wont start up unless I hold the key for 3-4 seconds..
And thats usually when its already warmed up and
maybe sat for an hour or 2. It isnt always like this
sometimes in the morning it does take 3-4 seconds.
(This is all without the gas pedal) Anyone have any
idea what might be causing this?
Thanks!
John
__________________________________________________
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
Small business owners...
Tell us what you think!
http://us.click.yahoo.com/vO1FAB/txzCAA ... /XoTolB/TM
starting problems
geoff murray
starting problems
Hi John,
I have a 1992 Subaru Liberty manual wagon ( same as Legacy ). I
found that it wasn't a good starter from cold too but if I turn the ignition
on and just give it a couple seconds before starting it starts much better.
Maybe it needs time for the fuel pump to pressurise?
Geoff Murray
www.geoffmurray.com
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Thursday, August 09, 2001 10:33 PM
Subject: [BC-BFLegacyWorks] starting problems
> And that's usually when its already warmed up and
> maybe sat for an hour or 2. It isn't always like this.
> Thanks!
> John
> Do You Yahoo!?
Geoff Murray
www.geoffmurray.com
> Thanks!
> John
> Do You Yahoo!?
Carl Andersen
starting problems
My 93 Touring Wagon does the same thing.
Carl
geoff murray wrote:
Hi John,
Geoff Murray
www.geoffmurray.com
> Thanks!
> John
> Do You Yahoo!?
Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service.
Carl
geoff murray wrote:
Hi John,
Geoff Murray
www.geoffmurray.com
> Thanks!
> John
> Do You Yahoo!?
Dave C
starting problems
I used to have problems with mine, but my coolant temp sensor was
giving me a CEL and replacing it made it start better and no CEL.
It could be a weak fuel pump, but i'm going with the simpler fix
> maybe sat for an hour or 2. It isn't always like this…
> Thanks!
> John
> Do You Yahoo!?
Messenger
> Thanks!
> John
> Do You Yahoo!?
Messenger
japtexas2001@yahoo.com
starting problems
I had the exact same symtoms on my 1994 Legacy Turbo Sedan. It
eventually went away, and I attribute that to one of two things. We
moved from Summit County, Colorado (elev. 9,600 feet) to Houston,
Texas (elev. 100 feet). That might have solved it. So my question to
you would be, "do you live 'at altitude?'". In any case, I don't know
why one is any better that the other.
The second thing that happened, at exactly the same time, was I found
a "suction" or "air pressure" type hose disconnected in the engine
compartment. This also caused "lurching" since the ECU went into safe-
mode, I think. Anyway, reconnected it, didn't even bother with an ECU
reset, and it worked fine. And has for over a year since.
Good luck,
Jim
Good luck,
Jim
Gord
starting problems
i live at sea level and my 91 Sports Sedan does the same thing.
Gord
-----Original Message-----
Sent: 9-Aug-01 9:34 AM
And that’s usually when its already warmed up and
maybe sat for an hour or 2. It isn’t always like this…
Thanks!
John
Do You Yahoo!?
Gord
Thanks!
John
Do You Yahoo!?
daniel.wilson@db.co.nz
starting problems
I find this very interesting, Only one of my Subaru's has trouble
starting and that is my new Subaru (automatic), and only first thing
in the morning on a cold morning. When I turn the key the car doesn't
rev up to 1500 - 2000 rpm and hunts for about 5 seconds then revs up
if it hasn't stalled. When turning the key and hold the key in the
start position about a second longer the starter motor gives the
engine slightly more revs and the car starts fine.
I wonder if it is the auto Subarus that are worse, because I know of
so many auto cars that stall upon first starting or when you put the
car in gear.
Dan
> Gord
> From: Nissan 240sx [mailto:nissans14@y...]
> To: BC-BFLegacyWorks@y...
> Thanks!
> John
car in gear.
Dan
> Gord
> Thanks!
> John
Josh Colombo
starting problems
Dan,
Mine does the same thing every now and then. Don't have a clue what it is.
Josh Colombo
jcc189@psu.edu < mailto:jcc189@psu.edu>
of beats and rhythm" - ME
From: daniel.wilson@db.co.nz [ mailto:daniel.wilson@db.co.nz]
Sent: Thursday, August 09, 2001 3:21 PM
Subject: [BC-BFLegacyWorks] Re: starting problems
car in gear.
Dan
> Gord
> From: Nissan 240sx [ mailto:nissans14@y...]
> Thanks!
> John
Josh Colombo
car in gear.
Dan
> Gord
> Thanks!
> John
