Suspension
Posted: Sun Aug 12, 2001 9:05 pm
That is normal (most common), it will be the same at the front, the NZ N/A
Subarus also have the RS front and rear struts. I am not sure about the
springs though. There are not too many variances with the Subaru suspension
setup.
Dan
This message (and attachments) may contain privileged and confidential information. If you are not the intended recipient you cannot use, distribute or copy the message or attachments. In such case, please delete this message and immediately notify the sender by return email. Opinions, conclusions and other information in this message that do not relate to the official business of my employer shall be understood as neither given nor endorsed by it.
setup.
Dan
