Should I rethink the header wrap/turbo sleeve?
Posted: Fri Feb 28, 2003 2:21 pm
by boostjunkie
Posted: Fri Feb 28, 2003 5:40 pm
I've heard this too, and have a friend that had his borla header crap because he wrapped it.....or it failed....and just happened to be wrapped.
I'd probably not do it. I'd suggest the Jet coating.
Posted: Fri Feb 28, 2003 5:41 pm
by boostjunkie
Anybody know how long that takes? This is my only car and I don't know if I could take off work for a week.
Depends on where you send it....see if there is a place to do it around your area.....
header heat wrap
Posted: Fri Mar 28, 2003 5:00 pm
by subiecar
I used the wrap initially on my first set of Borla headers and was not happy with the results :?. It probably hastened their cracks and ultimate failure of the headers. Fortunately, Borla replaced them with a series II upgrade for only the shipping charges; I`d recommend Borla to anyone when it comes down to warranty or service. Also, your heat wrap won`t help with any horsepower as far as that goes. I ended up using a patch of the stuff to keep turbo heat off my wires under the hood. My advice? Don`t waste your money (let guys like me experiment and save you the trouble :lol: )---Rod
Posted: Sat Mar 29, 2003 6:25 am
by JasonGrahn
Most coating places will only take a day or so to do your pipes if they're not backed up..
Here in the Puget Sound there is a REALLY good place in Auburn where i source out all my ceramic coating stuff too. they do an excellent job and will even clean your parts for you if you're nice to them. :D
Get the ceramic coating done. It's easier to work with, cools down faster, and looks a helluva lot better.
Ceramic coating.....
Posted: Wed May 07, 2003 4:44 pm
by subiecar
:D I found a local guy that does ceramic coating. He explained the incredible underhood heat reduction that occurs when this is done (approx. 200 degrees less!) I`m doing the headers, uppipe, downpipe and the inside of the tubes from the airbox to the throttle body (this will keep the cooler air in as I don`t have an I/C yet.) He does all the parts cleaning and everything is coated i/s and o/s (except the air tubes.) All this is being done for $300 or less! Also, he showed me a custom downpipe from a WRX that he`s doing; it had a separate tube for the wastegate running approx. 18" down and rejoining the pipe with an exhaust dam welded between the wastegate and the the turbine-it was too trick! He gave me the guy`s card and I`ll be calling him today as the bellmouth I just had done on my downpipe won`t be near enough to match this other mod. I`ll let you know what happens...and Josh, I`ll call you by Friday with M/C info.....getting closer to fire-up---ROD
Posted: Wed May 07, 2003 6:32 pm
Very cool Rod,
I actually picked up a brand new SVX MC on ebay for 20 bucks. vrg3 helped me find it. I emailed the guy selling it......from his emailings....he doesn't know a damn thing......he said the MC was 11/16" there's no freakin way.....I asked for a tracking number....haven't gotten a response......so hopefully I'll get it within the later part of this week, or next week.
I'm assuming this guy just had no clue what he had, and wanted a few bucks for it........and that it is in good working order.
Posted: Wed May 07, 2003 7:20 pm
by georryan
At the sake of sounding rather dumb....what is an MC? I think I should know this but currently I can't make out what it stands for.
-Ryan
Posted: Wed May 07, 2003 7:49 pm
by boostjunkie
Master Cylinder
Posted: Fri May 09, 2003 9:36 pm
by georryan
<slaps forhead> of course. I just changed one of those, for the clutch.
-Ryan
