I,ve been test fitting a water/air intercooler into my 91' and
recently checked my codes just for the heck of it and it told me
23,32,13 if I remember correctly. I looked them up in my book and it
says that my problem is with my O2 sensor, mass-airflow sensor, and
knok sensor. Has anyone run into these three codes at once before?,
or know of something that might trigger all of them? And can anyone
explain to me were the knok sensor is located, and can I reach it
without removing the intake manifold?
Ian
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/zoU8wD/4m7CAA ... /XoTolB/TM
what does it mean?
Mark Ward
what does it mean?
Hmm sounds familar, How does your engine run? Do you have power problems at
boost?
Mark
>Thanks
>Ian
FREE COLLEGE MONEY
boost?
Mark
>Thanks
>Ian
FREE COLLEGE MONEY
Ian Shastko
what does it mean?
Yes. The power feels weak. when I push down on the gas it surges. Sometimes
my boost guage needle wobbles apon acceleration. It almost feels like the
car goes faster when I start to lift my foot off the gas alittle. It really
feels like the car hits a wall durring acceleration yet it tries to go
beyond it. And my boost guage only reads 6.8psi to 7psi.
>From: Mark Ward <mark@rrunracing.com>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: Re: [BC-BFLegacyWorks] what does it mean?
>Date: Mon, 27 Aug 2001 09:49:20 -0700
>boost?
>Mark
> >Thanks
> >Ian
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
FREE COLLEGE MONEY
>boost?
>Mark
> >Thanks
> >Ian
FREE COLLEGE MONEY
Mark Ward
what does it mean?
Intake manifold leak. My dealer couldnt figure it out, he wanted to replace
all of those parts. pretty easy (kinda) job to do. Parts are about $10. you
need to get 2 intake gaskets. unbolt the intake runners (if you are lucky
you only need to remove the bolts on the runners) carefully lift up the
runners pull out the old gasket, put in the new one and rebolt it all
together. Doing it this way, you only get .5 inch clearance between the
manifold and cylinder head but you dont need anymore then that.
IF the gasket sticks and breaks apart, you have to tale all kinds of things
off so you can get a scraper onto the cylinder head and intake manifold.
you need to have clean surfaces for the gasket to work perfectly.
To test that this is in fact the problem, do this:
While the engine is running, open your hood and spray a fine mist of water
(squirt bottle) into the area where the mainfold meats the cylinder head.
If the car starts to almost stall, you have your problem. Check both sides...
Mark
www.rrunracing.com
> >boost?
> >Mark
> > >Thanks
> > >Ian
The Nissan Sentra
Everything but compact
http://NissanDriven.com
http://us.click.yahoo.com/3vsIKC/txlCAA ... /XoTolB/TM
Mark
www.rrunracing.com
> >boost?
> >Mark
> > >Thanks
> > >Ian
The Nissan Sentra
Dave C
what does it mean?
It sounds like your boost solenoid isn't working at all.
5.5-6.5PSI is where the wastegate will naturally open. Usually
the stock boost is about 9PSI.
Check all of the connections to the solenoid by the passenger
side strut tower. I highly recommend upgrading to at least a
manual boost controller to replace the stock version anyway.
Hallman makes a very good one, and there are a dozen others
available for less than $100.
--- In BC-BFLegacyWorks@y..., "Ian Shastko" <smotocon@h...>
surges. Sometimes
feels like the
really
> >From: Mark Ward <mark@r...>
> >Reply-To: BC-BFLegacyWorks@y...
> >boost?
> >Mark
me
book and it
sensor, and
once before?,
can anyone
reach it
> > >Thanks
> > >Ian
> > >Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
_______________
FREE COLLEGE MONEY
surges. Sometimes
feels like the
really
> >boost?
> >Mark
me
book and it
sensor, and
once before?,
can anyone
reach it
> > >Thanks
> > >Ian
_______________
FREE COLLEGE MONEY
daniel.wilson@db.co.nz
what does it mean?
Try connecting to to only a WOT switch, see how that goes.
Dan
Sometimes
like the
It really
go
problems at
> >boost?
> >Mark
and it
and
before?,
anyone
> > >Thanks
> > >Ian
Monitoring Service trial
http://us.click.yahoo.com/M8mxkD/bQ8CAA ... /XoTolB/TM
Dan
Sometimes
like the
It really
go
problems at
> >boost?
> >Mark
and it
and
before?,
anyone
> > >Thanks
> > >Ian
Ian Shastko
what does it mean?
what does "WOT" stand for wide open throttle? How would I wire that, and for
what? Boost? Turbo systems are new to me.
>From: daniel.wilson@db.co.nz
>Subject: [BC-BFLegacyWorks] Re: what does it mean?
>Date: Tue, 28 Aug 2001 00:15:14 -0000
>Dan
>Sometimes
>like the
>It really
>go
>problems at
> > >boost?
> > >Mark
>and it
>and
>before?,
>anyone
> > > >Thanks
> > > >Ian
FREE COLLEGE MONEY
>Dan
>Sometimes
>like the
>It really
>go
>problems at
> > >boost?
> > >Mark
>and it
>and
>before?,
>anyone
> > > >Thanks
> > > >Ian
FREE COLLEGE MONEY
jason grahn
what does it mean?
that would be something like a switch that is on your floor under your gas
pedal. Only at full accelleration (wide open throttle: WOT) would that
switch be activated. You could use that to wire NOS or a scramble switch to
turn up your boost, or an intercooler sprayer, or whatever you need it
for... =)
-Jason
>From: "Ian Shastko" <smotocon@hotmail.com>
>Subject: Re: [BC-BFLegacyWorks] Re: what does it mean?
>Date: Mon, 27 Aug 2001 18:59:26 -0700
>for
> >Dan
> >Sometimes
> >like the
> >It really
> >go
> >problems at
> > > >boost?
> > > >Mark
> >and it
> >and
> >before?,
> >anyone
> > > > >Thanks
> > > > >Ian
FREE COLLEGE MONEY
for... =)
-Jason
>for
> >Dan
> >Sometimes
> >like the
> >It really
> >go
> >problems at
> > > >boost?
> > > >Mark
> >and it
> >and
> >before?,
> >anyone
> > > > >Thanks
> > > > >Ian
FREE COLLEGE MONEY
what does it mean?
thanks for the suggestion but I would like to get it all in propper
working order befor I turn up the boost or add NOS. But I will most
likelly try a manual or electric boost controller.
your gas
that
switch to
it
> for... =)
> -Jason
> >From: "Ian Shastko" <smotocon@h...>
that, and
> >for
> > >From: daniel.wilson@d...
> > >Dan
surges.
> > >Sometimes
feels
> > >like the
alittle.
> > >It really
tries to
> > >go
power
> > >problems at
> > > > >boost?
> > > > >Mark
and
told me
book
> > >and it
sensor,
> > >and
> > >before?,
can
> > >anyone
reach it
> > > > > >Thanks
> > > > > >Ian
FREE COLLEGE MONEY
your gas
that
switch to
it
> for... =)
> -Jason
that, and
> >for
> > >Dan
surges.
> > >Sometimes
feels
> > >like the
alittle.
> > >It really
tries to
> > >go
power
> > >problems at
> > > > >boost?
> > > > >Mark
and
told me
book
> > >and it
sensor,
> > >and
> > >before?,
can
> > >anyone
reach it
> > > > > >Thanks
> > > > > >Ian
FREE COLLEGE MONEY
