One way to get a large heat exchanger...
Posted: Wed Oct 23, 2002 5:44 pm
I had considered this before, but a friend just brought it back to my attention.
This only applies to 5MT owners.
I swapped my 4EAT transmission out early this year, which removed a lot of weight from the front end of the car, and let me remove the transmission filter and hoses. There is, however, one large part that remains: The cooler.
This cooler was used to cool the transmission fluid, so it's meant to flow liquid, and should be easily adaptable for an air/water intercooling setup.
Now the only issue is this, if you have a 5MT, you don't have this, but if you have a 4EAT, it's already in use. 5MT owners could theoretically install the 4EAT radiator into their car and get a very large, very well placed heat exchanger with good airflow.
Just something to think about...
