ok for now i went and picked up a cheap pressure guage for about $8.
now the inlet manifold eh? ok, i'm looking at my haynes here, um,
could you maybe suggest a hose? i.e. air bypass hose, egr vacuum
hose, vacuum hose..... since i thought it should come off the
wastegate i'm kinda hesitate as to which hose i should even
consider. the haynes manual has a section for checking the boost and
the wastegate but the pic looks like the hose is coming from the
pressure exchange solenoid valve... it also says to connect it to
the intake pipe pressure hose.. i'm kinda stumped here. sorry, i
guess i'm a little thick on turbos yet...
--- In BC-BFLegacyWorks@y..., "Rod" <melrod@o...> wrote:
> mike,
> the VDO boost gauge I have is NOT the electrical type. The hose
connection
> for the boost gauge should NOT come off ex the wastegate. It
actually comes
> from the inlet manifold. There a few small hoses to choose from.
Take one of
> these off, fit a 'T' connection and then run it to your gauge. The
hose
> length shouldn't really make any difference as the hose dia size
supplied
> with the gauge is tiny.
> Rod... in OZ
> ps it's ok to bug me......... lol..
> ----- Original Message -----
> From: "mike p." <ob1poor@y...>
> To: <BC-BFLegacyWorks@y...>
> Sent: Saturday, September 08, 2001 8:26 AM
> Subject: [BC-BFLegacyWorks] Re: boost creep???
> > ok, i'm almost there. now the VDO guage you have, how does it
work?
> > is it off of pressure or is it electrical? if it is off of
pressure
> > from the pressure hose going to the wastegate the my next question
> > is, would the hose length you run to the guage from the pressure
hose
> > have any effect on what the guage reads? i promise i'll quit
bugging
> > you real soon. thanks
> > > before you do any boost mods the boost gauge is very important,
> > actually a
> > > must..
> > > the bleed valve i had is similar to one on the site
www.turbosmart.com.au
> > > check it out.
> > > The chip is much better.
> > > Rod
> > > Sent: Friday, September 07, 2001 1:34 PM
> > > > the bleed valve, would that be what i was talking about? i
just
> > got
> > > > done reading a piece about an eclipse or some rice thingy and
the
> > guy
> > > > just put an aquarium type valve in for a boost controller.
would
> > > > that work?
> > > > > ,for boost gauge, i have a VDO type. Shows vaccum and
positve
> > > > pressure, Was
> > > > > about $65 Aus. In the gauges test done it also came out
with
> > very
> > > > good
> > > > > accuracy. I have it fitted in the 'blank' next to the
cigarette
> > > > lighter.
> > > > > Fits perfectly.
> > > > > As for boost controller, i have a chip. It replaces
the 'bleed
> > > > valve' setup
> > > > > i used to have.
> > > > > cheers, rod ..in OZ
> > > > > Sent: Friday, September 07, 2001 1:19 PM
yeah i should, shouldn't i?:)
> > > > > > i just don't have the money to go buy a decent guage
right
> > now
> > > > > > (little problem with oil leaking i'm trying to get fixed,
> > thought
> > > > > > about just gasket sealing the sucker but?.?.). let me put
it
> > this
> > > > > > way, what is the cheapest guage and boost controller i
could
> > get?
> > > > > > i've read on other cars that you can controll the boost
with
> > just
> > > > a
> > > > > > simple valve put in a tee configuration off the wastegate
> > > > controller
> > > > > > is this the same with all turbo's? for the guage i'm
guessing
> > > > just a
> > > > > > mechanical needle guage would do, but how am i to read
that
> > going
> > > > > > down the road at 70? any suggestions:)?
> > > > > > > > you should have a boost gauge fitted.....
> > > > > > > > Rod.
> > > > > > > > Sent: Friday, September 07, 2001 10:30 AM
> > > > > > > > Subject: [BC-BFLegacyWorks] boost creep???
> > > > > > > > > the car: 92 legacy turbo
> > > > > > > > > the problem?: i've recently noticed a very slight
pull
> > or
> > > > tug
> > > > > > if
> > > > > > > you
> > > > > > > > > will while driving with the accelerator at a
constant
> > > > position
> > > > > > and
> > > > > > > > > was wondering if this is boost creep or not. you
see,
> > i'll
> > > > be
> > > > > > > going
> > > > > > > > > about 60 and then the car just seems to pull a
little
> > faster
> > > > > > and a
> > > > > > > > > little faster and so on. it's not bogging or
anything
> > and i
> > > > > > was
> > > > > > > just
> > > > > > > > > wandering if this was my boost creeping in or if it
had
> > > > > > something
> > > > > > > to
> > > > > > > > > do with the knock sensor. i just recently noticed
it
> > and
> > > > it's
> > > > > > not
> > > > > > > > > really noticeable unless you look for it. anyone
> > > > experinence
> > > > > > > this?
> > > > > > > > > To unsubscribe from this group, please send an
email to:
> > > > > > > > > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> > > > > > To unsubscribe from this group, please send an email to:
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/47cccB/4m7CAA ... /XoTolB/TM
