outer belt covers...
mike p.
is there any oil seals between the outer belt covers on the front of
an ej22t engine? my legacy has been leaking oil from what appears to
be pinched gaskets around the belt covers(timing belt), left top and
right bottom. or is this the front main seal? what kind of price
would i expect to pay a mechanic for replacind these? it keeps
getting worse and worse so any help would be great before i drive the
thing into a wall.... sorry it really smokes from the oil dripping
and it's very annoying.
oh yeah, one last thing, i looked all through my haynes manual and
can't seem to find anything relavent to this except the camshaft oil
seals. could they be the culprits?
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/47cccB/4m7CAA ... /XoTolB/TM
FREE COLLEGE MONEY
Samuel Barrett
Mike,
Sounds likely. Obviously I haven't looked at your car, or pulled it apart -
so take this for what it's worth. Supposedly, if you do schedualed
maintenence you're supposed to replace those every other time you do the
timing belt. The gasket in question could concievably be leaking oil from
the camshaft. As for the burning, the only thing I can think of, it's
finding its way down inside, between the plastic housing, down behind the
housing, under the engine, and onto the exhaust manifold. There's no place I
can think of on the front of that engine that could produce enough heat...
oh, it's a turbo, may be the heads could heat up enough to burn that oil, I
dunno, kinda doubt it actually. I can see why it would be annoying,
especially everytime you turned on the air vents, or the heater.
If you do the job, here's what you are looking at:
1. Remove timing belt camshaft sprockets, and related parts (I can field
strip mine and put it back together in ~50 minutes. I also have the FHI
reccomended camshaft and crankshaft wrenches. If you are new to doing this,
it'll prolly take you longer b/c you'll want to seperately identify/mark
every set of bolts you pull off and potentially a couple trips to Sears for
a missing socket size, or a breaker bar/extension, stripped bolt, etc.)
2. Remove valve rocker assembly (or don't, I think you might be able to skip
that step, I could be magnificently wrong but you'll know if you'll need to
pull it or not when you get to step 4. FHI reccomends pulling it, but it's
such a bear to put back in, especially on the right side... You might be
able to get away with just loosening the thing to the max. There are very
specific directions on re-tightening these things so if you need the
information on that lemme know.)
2. A. Remove the oil level gauge guide & attaching bolt.
3. Remove cam angle sensor
4. Remove camshaft support (on turbo, right side, it has 4 bolts, on NA's it
has 2. On the left side, both the turbos and the NA's have 3 bolts. FHI
documentation is not conclusive as to wether you have to pull this thing to
replace the oil seal IMHO. I'd try and leave it in if you can to prevent
issue mentioned in step 2.)
5. Remove O-ring (replace)
6. Remove oil seal (replace) [You may need to use specific tools to get this
thing in correctly, FHI reccomends using the oil seal guide pn# 499597000
and the oil seal installer pn# 499587100, and a mallet. This is prolly to
make sure the seal gets the right fit in the camshaft support]
Eat lunch, gather all the kings horses, and all the kings men, go back into
the garage, and put it all back together...
I've never done this specific job before, but I've replaced the head gaskets
on both sides of my engine, which requires one to do everything to the head,
except replace those 2 seals. I'm due for this exact same job when I do my
next timing belt sometime next summer - so let us know how it goes!
-=Sambo
-----Original Message-----
Sent: Sunday, September 09, 2001 3:22 PM
Subject: [BC-BFLegacyWorks] outer belt covers...
FREE COLLEGE MONEY
-=Sambo
FREE COLLEGE MONEY
Samuel Barrett
Now that I just re-read your question:
Those gaskets (if they are the one I'm thinking of) have *nothing* to do
with keeping oil in, mostly they just keep grime & dust away from the
camshaft. If it's meant to keep oil in the engine, without looking under my
own hood, You can't likely see it. Mine look pinched too because they are a
little tricky to keep in place when reassembling the plastics if you don't
have someone helping you out.
Price? No idea. $75/hr X 3-5 hours depending on experience of the tech. The
parts are less than $50 me thinks.
And that Haynes manual is more valuable to Subaru dealerships than it is to
Subaru owners, according to most of the mechanics I've asked about it. More
than one has said that if you follow their directions you'll end up doing
more damage than good on a couple of their replacement instructions...
Hence, I bought the FHI manuals.
-Sambo
FREE COLLEGE MONEY
-Sambo
FREE COLLEGE MONEY
ob1poor@yahoo.com
hehe, so... basically i should reschedule my plans for the next few
days after i decide to tackle this one eh? no really thanks though
for the help. i'm still undecided about if i'm going to try this or
if i should let it up to a garage. both decisions have their pros
and cons. i'm not too shabby with a wrench but then again it does
sound pretty involved. i'd just hate to get it apart and get stuck
at some point. as for the haynes being more a pain than anything,
well yeah, it pretty much cost my a control arm so far. how much is
a FHI manual, and where do you pick them up? well, thanks again.
to do
the
under my
they are a
you don't
tech. The
it is to
it. More
doing
instructions...
> -Sambo
> From: mike p. [mailto:ob1poor@y...]
> To: BC-BFLegacyWorks@y...
the
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
FREE COLLEGE MONEY
to do
the
under my
they are a
you don't
tech. The
it is to
it. More
doing
instructions...
> -Sambo
the
FREE COLLEGE MONEY
Samuel Barrett
Mike,
I got mine at www.subaruparts.com
They _are_ the most comprehensive manuals on our cars you will find
anywhere - guaranteed.
That value, comes at a price. I thinks I paid $100 for mine, they might be
cheaper by now. There is no worry about ordering things over the web from
subaruparts.com because they are a dealership, not some stupid internet
startup that might let you down. If you have a problem, call them up, get a
warm body, they have always been very easy to deal with in my experiences
with them. I bought the whole set: electronic, engine, body, general,
mechanical, and tranny.
There's nothing technically challenging to the job, if the oil seal is the
problem (figuring out what is wrong is half the battle). It's just a lot of
teardown and a quick replacement, then the re-construction. There's no parts
to machine, resurface, test, measure, etc. It's just taking things apart and
putting them back together (correctly). If you get it wrong, the worst thing
that's going to happen - you spend 2 Saturdays instead of 1 on the job,
re-doing it. Unless, you are a total block-head, like *ahem* me, who spent 3
straight days doing his first timing belt replacement, and eventually took
it to the shop b/c I couldn't count the teeth on the belt... I can make fun
of myself can't I? 42, 43, 45, 46....Oops! "That will be $120 please."
Next time spend a $1.20 on the grease marker. That's the lesson I learned on
that one...
What's really funny about that is: (I'm being candid here...) I didn't get
it wrong once, or even twice, or even four times - I actually botched it
five times in a row! Moron...
The next time I did the belt I _am_ proud to say, I got it right on the
first try. I picked up some tricks/hints from Mike and the fellas at Smart
Service Subaru
) I now have it permanently burned into my mind how to
replace a timing belt on the BC-BF Legacy.
If you get in a jam, just query the forum. Do a search on 'timing belt' if
you want to read up on that part of the job.
Again, good luck, and tell us how it went!
-Sambo
Sent: Sunday, September 09, 2001 7:59 PM
Subject: [BC-BFLegacyWorks] Re: outer belt covers...
to do
the
under my
they are a
you don't
tech. The
it is to
it. More
doing
instructions...
> -Sambo
the
FREE COLLEGE MONEY
that one...
Service Subaru
-Sambo
to do
the
under my
they are a
you don't
tech. The
it is to
it. More
doing
instructions...
> -Sambo
the
FREE COLLEGE MONEY
mike p.
ok, one last question for ya, what is the easiest way to find the TDC
for the #1 cylinder? is it as easy as aligning the mark on the
pulley with the zero on the timing scale or do i have to go through
the whole compression guage in the #1 spark plug hole and
disconecting the ignition coil pack and fuel pump and everything?
oh, and also can you give me a rundown of what "special" tools i
might need? i have a very good, pretty complete set of wrenches and
sockets from craftsman so that shouldn't be a problem. thanks again.
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
> From: ob1poor@y... [mailto:ob1poor@y...]
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
Samuel Barrett
Mike,
The biggest challenge you face is removing the camshaft pulley. That SOB is
a tricky one to get at w/o a camshaft wrench. The problem stems from the
fact there is almost nothing you can use to hold it in place when you are
trying to bust it loose. I have been thinking about this, and if you get the
timing belt covers off - *but don't remove the timing belt* - you might be
able to lock up the engine, via method of your choice, and get that nut
loose. Then proceed with the rest of the belt removal (easy) and then
re-address the camshaft sprocket you loosened just before. I ordered a
wrench b/c I didn't want to monkey around with it. Figuring out where to
order one is a trick. I had to cajole the info out of the head mechanic at
the Subie dealership in Bellevue, WA. I think I posted some info about this
previously on the board... I'm headed out to work and I don't have the info
handy - otherwise I'd tell ya.
As for TDC. Just line up the marks. There is a mark on each of the camshaft
sprockets, and the plastic housing behind them at 12 o'clock. Make sure you
use a grease pencil and mark the belt BEFORE you take it off. The new belts
have the marks already on them for you. The Crankshaft is a tricky one
however, the mark isn't as obvious as it is on the Cams, but it's there. The
cams are marked on the front lip, the crank is on the back, and it lines up
with a mark on the block, just after 12 o'clock. Instead of a notch, it's a
little bump on the crank sprocket. Mark the bump, cuz there's a few of them
on there, mark the belt where they line up with the notches, make arrows
pointing to the U.S. Driver's side for direction. Then yank the thing by
removing the tensioner and/or maybe an idler. When you go to put it back on,
line up your marks, put the tensioner/idler or both back in BUT DON"T YANK
THE PIN YET! Make damn sure you have the thing in there right - here's what
you do for a double check:
>From the crank mark count _teeth_ (not notches) in the belt to the right (as
you are facing the engine w/ your knees on the bumper) all the way to the
next mark. Should be 40.5 teeth (not notches). Do the same in the other
direction and you should have 44 teeth (not notches). If it all checks out
AND you have the tensioner in there right (there's a trick to that one too)
then yank the pin and slap the rest of the plastics, belts, and fans in
place and hit the ignition. See what you get.
As for the tensioner, when you put it back in place, put it in there loose
(like free moving) when you start the re-assembly. You'll need the slop to
get the belt in correctly. When you get everything just about right, as in
BEFORE you yank the pin, get a fairly hefty screwdriver in behind it, and
force the thing as hard toward the pulley as possible, then tighten that
thing down. NOW count your teeth on the belt and if everything checks out,
yank the pin. If you botch this, you will have a loose belt that will wear
out considerably faster, and/or potentially risking harm to the engine.
Wha-la! No timing lights, no compression gauges.
One other thing, make sure the crankshaft sprocket nut is tightend to no
less than 93 newton/meters, and no more than 103 newton/meters. I aim for
100. If you botch this, you will have a very big suprise one day when the
tooth on the sprocket breaks. Jason Grahn has been witness to the aftermath
of one of these... not pretty, very expensive.
-Sambo
Sent: Monday, September 10, 2001 7:22 AM
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
-Sambo
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
jason grahn
Mike-
Get a set of Subaru Factory Service Manuals and toss those Haynes ones,
they're crap. The Subaru ones are VERY accurate.
-Jason
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
FREE COLLEGE MONEY
Mike-
-Jason
FREE COLLEGE MONEY
jason grahn
Mike-
-Jason
FREE COLLEGE MONEY
Mike-
-Jason
FREE COLLEGE MONEY
Samuel Barrett
Mike,
Are you doing this job today (this weekend?). Hows it going?
=Sambo
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
=Sambo
> Mike,
might be
web from
internet
up, get a
experiences
general,
is the
a lot of
no parts
apart and
worst thing
job,
who spent 3
eventually took
make fun
please."
learned on
> that one...
didn't get
botched it
the
at Smart
> Service Subaru
how to
belt' if
> -Sambo
few
> to do
> the
> under my
> they are a
> you don't
> tech. The
> it is to
> it. More
up
> doing
> instructions...
> > -Sambo
of
to
and
> the
oil
FREE COLLEGE MONEY
ob1poor@yahoo.com
ha.... no... i wish. i'm waiting around for my check from the
irs... yeah you know, the one that was supposed to be $300. well
until i get that i'm up a creek. i have however found a guy to do
the whole timing belt and seals for me for aroun 75-100 dollars,
that's just the labor. i told him i'd get the belt and seals. i
figure that's not too bad, all together i'll be paying around $143.
he's a pretty good mech. and friend so i'm sure it'll be done right
also. i also might ask if he'd knock a bit off the labor end if i
helped. at any rate though i'm still waiting for that darn check.
and until then i'll be keeping an eye on my oil.... thanks for
asking though.
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
FREE COLLEGE MONEY
asking though.
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
FREE COLLEGE MONEY
ob1poor@yahoo.com
hey why did my profile go from mike p. to ob1poor@yahoo.com?
i didnt' change a thing, are there some changes taking place or
something on yahoo itself?
$143.
> asking though.
wrote:
> > Mike,
> > =Sambo
> TDC
through
everything?
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
the
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
the
> > worst thing
> the
> > job,
me,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
right
> on
> > the
fellas
> > at Smart
> > > Service Subaru
mind
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
manual
> and
> camshaft
> > oil
FREE COLLEGE MONEY
$143.
> asking though.
wrote:
> > Mike,
> > =Sambo
> TDC
through
everything?
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
the
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
the
> > worst thing
> the
> > job,
me,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
right
> on
> > the
fellas
> > at Smart
> > > Service Subaru
mind
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
manual
> and
> camshaft
> > oil
FREE COLLEGE MONEY
mike p.
sambo- ya know what, i was just sitting here reading the posts you so
painstakingly wrote for me on how to change my seals and i've finally
decided it.... i'm going to save myself a few bucks and change these
suckers myself, now hopefully my local autozone has a chain wrench i
can rent;) thanks a bunch, i'll let ya know how it turns out.
> hey why did my profile go from mike p. to ob1poor@y...?
well
do
> $143.
right
i
check.
> > asking though.
> wrote:
> > > Mike,
> > > =Sambo
the
> > TDC
> through
> everything?
i
wrenches
> > and
> > again.
> > wrote:
> > > > Mike,
will
> > find
> they
> > > might be
> the
> > > web from
stupid
> > > internet
> them
> > > up, get a
> > > experiences
> > > general,
oil
> > seal
> > > is the
> > just
> > > a lot of
> > There's
> > > no parts
> > things
> > > apart and
> the
> > > worst thing
on
> > the
> > > job,
> me,
> > > who spent 3
> > > eventually took
I
> > can
> > > make fun
> > > please."
lesson
> I
> > > learned on
> > > > that one...
I
> > > didn't get
> > > botched it
> right
> > on
> > > the
> fellas
> > > at Smart
> > > > Service Subaru
> mind
> > > how to
> on 'timing
> > > belt' if
> > > > -Sambo
> next
> > > few
> > though
> this
> > or
> pros
> does
> > stuck
> anything,
> much
> > is
> again.
<LEVATHIAN@s...>
> > *nothing*
> > > > to do
away
> > from
> > > > the
> > looking
> > > > under my
> because
> > > > they are a
plastics
> if
> > > > you don't
of
> > the
> > > > tech. The
dealerships
> > than
> > > > it is to
asked
> > about
> > > > it. More
you'll
> > end
> > > up
> > > > doing
> > > > instructions...
> > > > > -Sambo
> > front
> > > of
> > appears
> > > to
left
> > top
> > > and
> price
keeps
> > drive
> > > > the
> > dripping
> manual
> > and
> > camshaft
> > > oil
FREE COLLEGE MONEY
well
do
> $143.
right
i
check.
> > asking though.
> wrote:
> > > Mike,
> > > =Sambo
the
> > TDC
> through
> everything?
i
wrenches
> > and
> > again.
> > wrote:
> > > > Mike,
will
> > find
> they
> > > might be
> the
> > > web from
stupid
> > > internet
> them
> > > up, get a
> > > experiences
> > > general,
oil
> > seal
> > > is the
> > just
> > > a lot of
> > There's
> > > no parts
> > things
> > > apart and
> the
> > > worst thing
on
> > the
> > > job,
> me,
> > > who spent 3
> > > eventually took
I
> > can
> > > make fun
> > > please."
lesson
> I
> > > learned on
> > > > that one...
I
> > > didn't get
> > > botched it
> right
> > on
> > > the
> fellas
> > > at Smart
> > > > Service Subaru
> mind
> > > how to
> on 'timing
> > > belt' if
> > > > -Sambo
> next
> > > few
> > though
> this
> > or
> pros
> does
> > stuck
> anything,
> much
> > is
> again.
<LEVATHIAN@s...>
> > *nothing*
> > > > to do
away
> > from
> > > > the
> > looking
> > > > under my
> because
> > > > they are a
plastics
> if
> > > > you don't
of
> > the
> > > > tech. The
dealerships
> > than
> > > > it is to
asked
> > about
> > > > it. More
you'll
> > end
> > > up
> > > > doing
> > > > instructions...
> > > > > -Sambo
> > front
> > > of
> > appears
> > > to
left
> > top
> > > and
> price
keeps
> > drive
> > > > the
> > dripping
> manual
> > and
> > camshaft
> > > oil
FREE COLLEGE MONEY
mike p.
oh, one last thing, i'm a little confused on the oil pump housing
gasket and i think it was the crankshaft gasket. well it says in my
haynes(yeah i know) under the section for changing the crankshaft
seal to remove the gasket, but it called it the pump housing gasket
and i was wondering if these are one in the same or two entirely
different gaskets? just need to know what all i should pick up from
advanced auto before my suby is in pieces and i'm stranded.
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
Samuel Barrett
Mike,
I'm on the way out the door, but the job you listed below is entirely
different than the one you originally posted about. Now you are talking
about doing the gasket on the oil pump, before, it sounded like you wanted
to do the camshaft oil seal. That's another story - I haven't been there
before. I just picked up the FHI manual and it says it's fairly straight
forward - remove, replace, re-assemble. But nothing makes up for experience
and I haven't done this one myself...yet.
I'll do a write up on what FHI has to say when I get home from work.
=Sambo
P.S. forget renting the chain wrench. The timing belt on Sube's is exactly
that: a belt.
Sent: Tuesday, September 18, 2001 6:59 AM
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
=Sambo
that: a belt.
> Mike,
> =Sambo
TDC
and
again.
wrote:
> > Mike,
find
> might be
> web from
> internet
> up, get a
> experiences
> general,
seal
> is the
just
> a lot of
There's
> no parts
things
> apart and
> worst thing
the
> job,
> who spent 3
> eventually took
can
> make fun
> please."
> learned on
> > that one...
> didn't get
> botched it
on
> the
> at Smart
> > Service Subaru
> how to
> belt' if
> > -Sambo
> few
though
or
stuck
is
*nothing*
> > to do
from
> > the
looking
> > under my
> > they are a
> > you don't
the
> > tech. The
than
> > it is to
about
> > it. More
end
> up
> > doing
> > instructions...
> > > -Sambo
front
> of
appears
> to
top
> and
drive
> > the
dripping
and
camshaft
> oil
mike p.
oh no, see that's where i got confused. now keep in mind this is
coming from the haynes manual. but it says under the crankshaft oil
seal replacement how to replace the seals but the caption under the
accompianing picture says to "pull the seal from the oil pump housing
taking care not to damage the crankshaft surface or the oil pump
housing". now what are they talking about? i'm thinking that since
the oil pump drives directly off of the crankshaft(correct?) that
this would be the crankshaft seal but i just want to make sure so i
know i have all the seals i need that should be replaced since i have
it all torn down anyway. and the chain wrench i was talking about
was just that-a wrench made from a chain to hold the crankshaft
pulley
thanks sam i really do appreciate all the help
mike p.
> Mike,
entirely
talking
wanted
there
straight
experience
> =Sambo
exactly
> that: a belt.
so
finally
these
wrote:
> > Mike,
> > =Sambo
> TDC
through
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
> > worst thing
> the
> > job,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
> on
> > the
fellas
> > at Smart
> > > Service Subaru
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
> and
> camshaft
> > oil
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
pulley
mike p.
> Mike,
entirely
talking
wanted
there
straight
experience
> =Sambo
exactly
> that: a belt.
so
finally
these
wrote:
> > Mike,
> > =Sambo
> TDC
through
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
> > worst thing
> the
> > job,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
> on
> > the
fellas
> > at Smart
> > > Service Subaru
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
> and
> camshaft
> > oil
Samuel Barrett
Correct. The oil pump drives off the crankshaft. It's right behind the cog.
You have to pull the oil pump. It's basically shaped like a horseshoe, or an
upside down letter "U". (I need to go get a scanner...) and the crank runs
directly through the arch. After removing the 7 bolts (remember this is from
FHI), you'll need a couple of screwdrivers to get behind it and lever it off
the engine block (careful: don't scratch the block). Drain the engine oil
first (duh). Drain the coolant (not sure why, but that's what it says).
Remove the belt covers & belts. Remove the water pump (not sure about that
one either). Then remove the oil pump.
FHI emphasises: Be careful not to scratch mating surfaces of cylinder block
and oil pump.
You'll need some "goup" or that weird sticky packing fluid to re-pack the
mating surfaces.
FHI also emphasises: Apply liquid packing to oil pressure switch threads
before installation. (I don't know what that means either because there is
no such definition in any of the pictures here as to what that switch is,
but they stated it for a reason).
This looks like a slightly complex proceedure... It also states: "inscribe
alignment marks on inner and outer rotors so that they can be replaced in
their original positions during reassembly. (those are the guts of the thing
FYI. They are round and bumpy.)
More FHI emphasis: Before removing the relief valve, loosen plug when
removing oil pump from cylinder block.
So you'll need to order an
O-ring
Front oil seal
And depending on what you find when you get there: an oil seal installer,
same as mentioned in previous posts...
Hope that helps...
-Sambo
Sent: Tuesday, September 18, 2001 9:27 AM
pulley
mike p.
> Mike,
entirely
talking
wanted
there
straight
experience
> =Sambo
exactly
> that: a belt.
so
finally
these
wrote:
> > Mike,
> > =Sambo
> TDC
through
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
> > worst thing
> the
> > job,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
> on
> > the
fellas
> > at Smart
> > > Service Subaru
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
> and
> camshaft
> > oil
and oil pump.
mating surfaces.
O-ring
Front oil seal
Hope that helps...
-Sambo
pulley
mike p.
> Mike,
entirely
talking
wanted
there
straight
experience
> =Sambo
exactly
> that: a belt.
so
finally
these
wrote:
> > Mike,
> > =Sambo
> TDC
through
> and
> again.
> wrote:
> > > Mike,
> find
they
> > might be
> > web from
> > internet
them
> > up, get a
> > experiences
> > general,
> seal
> > is the
> just
> > a lot of
> There's
> > no parts
> things
> > apart and
> > worst thing
> the
> > job,
> > who spent 3
> > eventually took
> can
> > make fun
> > please."
I
> > learned on
> > > that one...
> > didn't get
> > botched it
> on
> > the
fellas
> > at Smart
> > > Service Subaru
> > how to
on 'timing
> > belt' if
> > > -Sambo
next
> > few
> though
this
> or
pros
does
> stuck
anything,
much
> is
again.
> *nothing*
> > > to do
> from
> > > the
> looking
> > > under my
because
> > > they are a
if
> > > you don't
> the
> > > tech. The
> than
> > > it is to
> about
> > > it. More
> end
> > up
> > > doing
> > > instructions...
> > > > -Sambo
> front
> > of
> appears
> > to
> top
> > and
price
> drive
> > > the
> dripping
> and
> camshaft
> > oil
Samuel Barrett
Howz it going? Did you do it this weekend?
=Sambo
Sent: Monday, September 17, 2001 5:18 PM
well
do
> $143.
right
i
check.
> > asking though.
> wrote:
> > > Mike,
> > > =Sambo
the
> > TDC
> through
> everything?
i
wrenches
> > and
> > again.
> > wrote:
> > > > Mike,
will
> > find
> they
> > > might be
> the
> > > web from
stupid
> > > internet
> them
> > > up, get a
> > > experiences
> > > general,
oil
> > seal
> > > is the
> > just
> > > a lot of
> > There's
> > > no parts
> > things
> > > apart and
> the
> > > worst thing
on
> > the
> > > job,
> me,
> > > who spent 3
> > > eventually took
I
> > can
> > > make fun
> > > please."
lesson
> I
> > > learned on
> > > > that one...
I
> > > didn't get
> > > botched it
> right
> > on
> > > the
> fellas
> > > at Smart
> > > > Service Subaru
> mind
> > > how to
> on 'timing
> > > belt' if
> > > > -Sambo
> next
> > > few
> > though
> this
> > or
> pros
> does
> > stuck
> anything,
> much
> > is
> again.
<LEVATHIAN@s...>
> > *nothing*
> > > > to do
away
> > from
> > > > the
> > looking
> > > > under my
> because
> > > > they are a
plastics
> if
> > > > you don't
of
> > the
> > > > tech. The
dealerships
> > than
> > > > it is to
asked
> > about
> > > > it. More
you'll
> > end
> > > up
> > > > doing
> > > > instructions...
> > > > > -Sambo
> > front
> > > of
> > appears
> > > to
left
> > top
> > > and
> price
keeps
> > drive
> > > > the
> > dripping
> manual
> > and
> > camshaft
> > > oil
=Sambo
well
do
> $143.
right
i
check.
> > asking though.
> wrote:
> > > Mike,
> > > =Sambo
the
> > TDC
> through
> everything?
i
wrenches
> > and
> > again.
> > wrote:
> > > > Mike,
will
> > find
> they
> > > might be
> the
> > > web from
stupid
> > > internet
> them
> > > up, get a
> > > experiences
> > > general,
oil
> > seal
> > > is the
> > just
> > > a lot of
> > There's
> > > no parts
> > things
> > > apart and
> the
> > > worst thing
on
> > the
> > > job,
> me,
> > > who spent 3
> > > eventually took
I
> > can
> > > make fun
> > > please."
lesson
> I
> > > learned on
> > > > that one...
I
> > > didn't get
> > > botched it
> right
> > on
> > > the
> fellas
> > > at Smart
> > > > Service Subaru
> mind
> > > how to
> on 'timing
> > > belt' if
> > > > -Sambo
> next
> > > few
> > though
> this
> > or
> pros
> does
> > stuck
> anything,
> much
> > is
> again.
<LEVATHIAN@s...>
> > *nothing*
> > > > to do
away
> > from
> > > > the
> > looking
> > > > under my
> because
> > > > they are a
plastics
> if
> > > > you don't
of
> > the
> > > > tech. The
dealerships
> > than
> > > > it is to
asked
> > about
> > > > it. More
you'll
> > end
> > > up
> > > > doing
> > > > instructions...
> > > > > -Sambo
> > front
> > > of
> > appears
> > > to
left
> > top
> > > and
> price
keeps
> > drive
> > > > the
> > dripping
> manual
> > and
> > camshaft
> > > oil
mike p.
no i'm still waiting for my belt and seals.... and my whiteline
swaybar endlinks
hopefully soon though... i'll let you know, or
maybe(hopefully not) have to ask you a question or two if i get
stuck. one thing though, when you did yours(i'm assuming yours) did
you have to take the bumper off or did you have room to work(again
hopefully not)? i just hope everything goes ok...
> =Sambo
so
finally
these
i
the
> well
> do
dollars,
i
> > $143.
> right
if
> i
> check.
> > > asking though.
> > wrote:
> > > > Mike,
> > > > =Sambo
> the
> > > TDC
the
> > through
> > everything?
tools
> i
> wrenches
> > > and
thanks
> > > again.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> will
> > > find
mine,
> > they
> > > > might be
over
> > the
> > > > web from
> stupid
> > > > internet
call
> > them
> > > > up, get a
my
> > > > experiences
body,
> > > > general,
> oil
> > > seal
> > > > is the
It's
> > > just
> > > > a lot of
> > > There's
> > > > no parts
> > > things
> > > > apart and
wrong,
> > the
> > > > worst thing
> on
> > > the
> > > > job,
*ahem*
> > me,
> > > > who spent 3
> > > > eventually took
belt...
> I
> > > can
> > > > make fun
$120
> > > > please."
> lesson
> > I
> > > > learned on
> > > > > that one...
here...)
> I
> > > > didn't get
actually
> > > > botched it
> > right
> > > on
> > > > the
> > fellas
> > > > at Smart
> > > > > Service Subaru
> > mind
> > > > how to
> > on 'timing
> > > > belt' if
> > > > > -Sambo
the
> > next
> > > > few
thanks
> > > though
try
> > this
> > > or
their
> > pros
it
> > does
get
> > > stuck
> > anything,
how
> > much
> > > is
> > again.
> <LEVATHIAN@s...>
> > > *nothing*
> > > > > to do
> away
> > > from
> > > > > the
without
> > > looking
> > > > > under my
> > because
> > > > > they are a
> plastics
> > if
> > > > > you don't
experience
> of
> > > the
> > > > > tech. The
> dealerships
> > > than
> > > > > it is to
> asked
> > > about
> > > > > it. More
> you'll
> > > end
> > > > up
> > > > > doing
> > > > > instructions...
> > > > > > -Sambo
the
> > > front
> > > > of
> > > appears
> > > > to
> left
> > > top
> > > > and
of
> > price
> keeps
i
> > > drive
> > > > > the
> > > dripping
> > manual
> > > and
> > > camshaft
> > > > oil
swaybar endlinks
> =Sambo
so
finally
these
i
the
> well
> do
dollars,
i
> > $143.
> right
if
> i
> check.
> > > asking though.
> > wrote:
> > > > Mike,
> > > > =Sambo
> the
> > > TDC
the
> > through
> > everything?
tools
> i
> wrenches
> > > and
thanks
> > > again.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> will
> > > find
mine,
> > they
> > > > might be
over
> > the
> > > > web from
> stupid
> > > > internet
call
> > them
> > > > up, get a
my
> > > > experiences
body,
> > > > general,
> oil
> > > seal
> > > > is the
It's
> > > just
> > > > a lot of
> > > There's
> > > > no parts
> > > things
> > > > apart and
wrong,
> > the
> > > > worst thing
> on
> > > the
> > > > job,
*ahem*
> > me,
> > > > who spent 3
> > > > eventually took
belt...
> I
> > > can
> > > > make fun
$120
> > > > please."
> lesson
> > I
> > > > learned on
> > > > > that one...
here...)
> I
> > > > didn't get
actually
> > > > botched it
> > right
> > > on
> > > > the
> > fellas
> > > > at Smart
> > > > > Service Subaru
> > mind
> > > > how to
> > on 'timing
> > > > belt' if
> > > > > -Sambo
the
> > next
> > > > few
thanks
> > > though
try
> > this
> > > or
their
> > pros
it
> > does
get
> > > stuck
> > anything,
how
> > much
> > > is
> > again.
> <LEVATHIAN@s...>
> > > *nothing*
> > > > > to do
> away
> > > from
> > > > > the
without
> > > looking
> > > > > under my
> > because
> > > > > they are a
> plastics
> > if
> > > > > you don't
experience
> of
> > > the
> > > > > tech. The
> dealerships
> > > than
> > > > > it is to
> asked
> > > about
> > > > > it. More
> you'll
> > > end
> > > > up
> > > > > doing
> > > > > instructions...
> > > > > > -Sambo
the
> > > front
> > > > of
> > > appears
> > > > to
> left
> > > top
> > > > and
of
> > price
> keeps
i
> > > drive
> > > > > the
> > > dripping
> > manual
> > > and
> > > camshaft
> > > > oil
Josh Colombo
Hey mike, let us know how those end links work out and what sort of improvement they make.
I'm curious...
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
Sent: Saturday, September 22, 2001 5:47 PM
swaybar endlinks
> =Sambo
so
finally
these
i
the
> well
> do
dollars,
i
> > $143.
> right
if
> i
> check.
> > > asking though.
> > wrote:
> > > > Mike,
> > > > =Sambo
> the
> > > TDC
the
> > through
> > everything?
tools
> i
> wrenches
> > > and
thanks
> > > again.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> will
> > > find
mine,
> > they
> > > > might be
over
> > the
> > > > web from
> stupid
> > > > internet
call
> > them
> > > > up, get a
my
> > > > experiences
body,
> > > > general,
> oil
> > > seal
> > > > is the
It's
> > > just
> > > > a lot of
> > > There's
> > > > no parts
> > > things
> > > > apart and
wrong,
> > the
> > > > worst thing
> on
> > > the
> > > > job,
*ahem*
> > me,
> > > > who spent 3
> > > > eventually took
belt...
> I
> > > can
> > > > make fun
$120
> > > > please."
> lesson
> > I
> > > > learned on
> > > > > that one...
here...)
> I
> > > > didn't get
actually
> > > > botched it
> > right
> > > on
> > > > the
> > fellas
> > > > at Smart
> > > > > Service Subaru
> > mind
> > > > how to
> > on 'timing
> > > > belt' if
> > > > > -Sambo
the
> > next
> > > > few
thanks
> > > though
try
> > this
> > > or
their
> > pros
it
> > does
get
> > > stuck
> > anything,
how
> > much
> > > is
> > again.
> <LEVATHIAN@s...>
> > > *nothing*
> > > > > to do
> away
> > > from
> > > > > the
without
> > > looking
> > > > > under my
> > because
> > > > > they are a
> plastics
> > if
> > > > > you don't
experience
> of
> > > the
> > > > > tech. The
> dealerships
> > > than
> > > > > it is to
> asked
> > > about
> > > > > it. More
> you'll
> > > end
> > > > up
> > > > > doing
> > > > > instructions...
> > > > > > -Sambo
the
> > > front
> > > > of
> > > appears
> > > > to
> left
> > > top
> > > > and
of
> > price
> keeps
i
> > > drive
> > > > > the
> > > dripping
> > manual
> > > and
> > > camshaft
> > > > oil
ADVERTISEMENT
<http://rd.yahoo.com/M=210544.1579876.31 ... 20_105_264> Lose 20 lbs by November 12th
<http://us.adserver.yahoo.com/l?M=210544 ... =568119226>
I'm curious...
Josh Colombo
swaybar endlinks
> =Sambo
so
finally
these
i
the
> well
> do
dollars,
i
> > $143.
> right
if
> i
> check.
> > > asking though.
> > wrote:
> > > > Mike,
> > > > =Sambo
> the
> > > TDC
the
> > through
> > everything?
tools
> i
> wrenches
> > > and
thanks
> > > again.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> will
> > > find
mine,
> > they
> > > > might be
over
> > the
> > > > web from
> stupid
> > > > internet
call
> > them
> > > > up, get a
my
> > > > experiences
body,
> > > > general,
> oil
> > > seal
> > > > is the
It's
> > > just
> > > > a lot of
> > > There's
> > > > no parts
> > > things
> > > > apart and
wrong,
> > the
> > > > worst thing
> on
> > > the
> > > > job,
*ahem*
> > me,
> > > > who spent 3
> > > > eventually took
belt...
> I
> > > can
> > > > make fun
$120
> > > > please."
> lesson
> > I
> > > > learned on
> > > > > that one...
here...)
> I
> > > > didn't get
actually
> > > > botched it
> > right
> > > on
> > > > the
> > fellas
> > > > at Smart
> > > > > Service Subaru
> > mind
> > > > how to
> > on 'timing
> > > > belt' if
> > > > > -Sambo
the
> > next
> > > > few
thanks
> > > though
try
> > this
> > > or
their
> > pros
it
> > does
get
> > > stuck
> > anything,
how
> > much
> > > is
> > again.
> <LEVATHIAN@s...>
> > > *nothing*
> > > > > to do
> away
> > > from
> > > > > the
without
> > > looking
> > > > > under my
> > because
> > > > > they are a
> plastics
> > if
> > > > > you don't
experience
> of
> > > the
> > > > > tech. The
> dealerships
> > > than
> > > > > it is to
> asked
> > > about
> > > > > it. More
> you'll
> > > end
> > > > up
> > > > > doing
> > > > > instructions...
> > > > > > -Sambo
the
> > > front
> > > > of
> > > appears
> > > > to
> left
> > > top
> > > > and
of
> > price
> keeps
i
> > > drive
> > > > > the
> > > dripping
> > manual
> > > and
> > > camshaft
> > > > oil
ADVERTISEMENT
mike p.
will do, i'm expecting some spectacular results just for the fact
that mine are shot, to say the least. every time i make a turn or
hit a bump etc. you can hear the front left one(it make a loud click
kinda noise) and just recently the right one started. oh, boy i
can't wait:) i also have my gr2's sitting here ready to go on.
hopefully i'll get everything on in one shot. i have to come up with
some money to rent some tools though(spring compressor, and chain
wrench for my crankshaft, cam/crank seals and timing belt are also
getting replaced) boy, i got some work to do eh?
> I'm curious...
> Josh Colombo
> jcc189@p... <mailto:jcc189@p...>
> swaybar endlinks
or
did
> > =Sambo
you
> so
> finally
> these
wrench
> i
> the
> > well
to
> > do
> dollars,
seals.
> i
> > > $143.
> > right
> if
> > i
> > check.
for
> > > > asking though.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> > > > > =Sambo
find
> > the
> > > > TDC
> the
> > > through
> > > everything?
> tools
> > i
> > wrenches
> > > > and
> thanks
> > > > again.
> <LEVATHIAN@s...>
> > > > wrote:
> > > > > > Mike,
> > will
> > > > find
> mine,
> > > they
> > > > > might be
> over
> > > the
> > > > > web from
> > stupid
> > > > > internet
> call
> > > them
> > > > > up, get a
in
> my
> > > > > experiences
> body,
> > > > > general,
the
> > oil
> > > > seal
> > > > > is the
> It's
> > > > just
> > > > > a lot of
construction.
> > > > There's
> > > > > no parts
taking
> > > > things
> > > > > apart and
> wrong,
> > > the
> > > > > worst thing
1
> > on
> > > > the
> > > > > job,
> *ahem*
> > > me,
> > > > > who spent 3
and
> > > > > eventually took
> belt...
> > I
> > > > can
> > > > > make fun
> $120
> > > > > please."
> > lesson
> > > I
> > > > > learned on
> > > > > > that one...
> here...)
> > I
> > > > > didn't get
> actually
> > > > > botched it
it
> > > right
> > > > on
> > > > > the
the
> > > fellas
> > > > > at Smart
> > > > > > Service Subaru
my
> > > mind
> > > > > how to
> > > on 'timing
> > > > > belt' if
> > > > > > -Sambo
> the
> > > next
> > > > > few
> thanks
> > > > though
> try
> > > this
> > > > or
> their
> > > pros
again
> it
> > > does
> get
> > > > stuck
> > > anything,
> how
> > > much
> > > > is
thanks
> > > again.
> > <LEVATHIAN@s...>
have
> > > > *nothing*
> > > > > > to do
> > away
> > > > from
> > > > > > the
> without
> > > > looking
> > > > > > under my
too
> > > because
> > > > > > they are a
> > plastics
> > > if
> > > > > > you don't
> experience
> > of
> > > > the
> > > > > > tech. The
> > dealerships
> > > > than
> > > > > > it is to
> > asked
> > > > about
> > > > > > it. More
> > you'll
> > > > end
> > > > > up
> > > > > > doing
> > > > > > instructions...
> > > > > > > -Sambo
> the
> > > > front
> > > > > of
what
> > > > appears
> > > > > to
> > left
> > > > top
> > > > > and
> of
> > > price
it
> > keeps
before
> i
> > > > drive
> > > > > > the
oil
> > > > dripping
> > > manual
> > > > and
> > > > camshaft
> > > > > oil
> I'm curious...
> Josh Colombo
> swaybar endlinks
or
did
> > =Sambo
you
> so
> finally
> these
wrench
> i
> the
> > well
to
> > do
> dollars,
seals.
> i
> > > $143.
> > right
> if
> > i
> > check.
for
> > > > asking though.
<LEVATHIAN@s...>
> > > wrote:
> > > > > Mike,
> > > > > =Sambo
find
> > the
> > > > TDC
> the
> > > through
> > > everything?
> tools
> > i
> > wrenches
> > > > and
> thanks
> > > > again.
> <LEVATHIAN@s...>
> > > > wrote:
> > > > > > Mike,
> > will
> > > > find
> mine,
> > > they
> > > > > might be
> over
> > > the
> > > > > web from
> > stupid
> > > > > internet
> call
> > > them
> > > > > up, get a
in
> my
> > > > > experiences
> body,
> > > > > general,
the
> > oil
> > > > seal
> > > > > is the
> It's
> > > > just
> > > > > a lot of
construction.
> > > > There's
> > > > > no parts
taking
> > > > things
> > > > > apart and
> wrong,
> > > the
> > > > > worst thing
1
> > on
> > > > the
> > > > > job,
> *ahem*
> > > me,
> > > > > who spent 3
and
> > > > > eventually took
> belt...
> > I
> > > > can
> > > > > make fun
> $120
> > > > > please."
> > lesson
> > > I
> > > > > learned on
> > > > > > that one...
> here...)
> > I
> > > > > didn't get
> actually
> > > > > botched it
it
> > > right
> > > > on
> > > > > the
the
> > > fellas
> > > > > at Smart
> > > > > > Service Subaru
my
> > > mind
> > > > > how to
> > > on 'timing
> > > > > belt' if
> > > > > > -Sambo
> the
> > > next
> > > > > few
> thanks
> > > > though
> try
> > > this
> > > > or
> their
> > > pros
again
> it
> > > does
> get
> > > > stuck
> > > anything,
> how
> > > much
> > > > is
thanks
> > > again.
> > <LEVATHIAN@s...>
have
> > > > *nothing*
> > > > > > to do
> > away
> > > > from
> > > > > > the
> without
> > > > looking
> > > > > > under my
too
> > > because
> > > > > > they are a
> > plastics
> > > if
> > > > > > you don't
> experience
> > of
> > > > the
> > > > > > tech. The
> > dealerships
> > > > than
> > > > > > it is to
> > asked
> > > > about
> > > > > > it. More
> > you'll
> > > > end
> > > > > up
> > > > > > doing
> > > > > > instructions...
> > > > > > > -Sambo
> the
> > > > front
> > > > > of
what
> > > > appears
> > > > > to
> > left
> > > > top
> > > > > and
> of
> > > price
it
> > keeps
before
> i
> > > > drive
> > > > > > the
oil
> > > > dripping
> > > manual
> > > > and
> > > > camshaft
> > > > > oil
