Need EJ20 parts...
Posted: Sat Sep 29, 2001 9:40 pm
by czo79@hotmail.com
Hello, I have a 91 US legacy turbo with an 94 jspec wrx ej20 closed
deck engine. I need to find a stock 440cc side feed injector, or
even just a part # if anyone knows. Failing that, if anyone knows of
larger injectors that will swap right in w/o needing to modify the
fuel rail or if they also know where I can get a custom fuel rail.
But if i go larger, I want them to work with stock engine manegment.
I also have a collapsed hydraulic lifter (I almost positive their
hydraulic) and need to find a new lifter. I am also looking for a
source for a 94 wrx ECU. Does anyone know if this ECU will swap
right in? I imagine the connectors are different, but I am hoping
all the engine sensors and such will be the same. If anyone can help
me find any of these parts, I would be grateful as my car is laid up
till I get them. If not, hopefully someone might be able to point me
in the right direction, or maybe get me some part #'s, then I think I
will be able to get them myself. Perhaps some of the UK, AUS, or NZ
people on the board can help.
Much Thanks,
Micum
91 Legacy Turbo Sport EJ20-RA
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/ujOgTC/4m7CAA ... /XoTolB/TM
Need EJ20 parts...
Posted: Sat Sep 29, 2001 11:25 pm
by Rod Grosvenor
Try R.C. Engineering in Cal. for the injectors & fuel rails. Their Phone # is (310) 320-2277; ask for Wayne in tech-he was very helpful. Their website is www.rceng.com if you`d like to look at that first. Both `91 & `94 engines were OBD-I so the hook-ups should be similar. Try Teague`s Auto back east; he has alot of used/older parts in good condition-phone # is (828) 683-9218. Good luck---ROD (AZ.)
----- Original Message -----
Sent: Saturday, September 29, 2001 6:22 PM
Subject: [BC-BFLegacyWorks] Need EJ20 parts...
Much Thanks,
Micum
ADVERTISEMENT
<http://rd.yahoo.com/M=168643.1620686.31 ... Fcid=12715>
<http://us.adserver.yahoo.com/l?M=168643 ... =380841644>
Need EJ20 parts...
Posted: Sun Sep 30, 2001 12:42 am
by b.lam@usa.net
I would like to know more about the engine swap, could you tell me
some more about the informations?
Does the engine directly bolt on the stock engine and tranny mount?
Do you have to change the transimission all together?
Ben
FREE COLLEGE MONEY
Need EJ20 parts...
Posted: Sun Sep 30, 2001 2:36 pm
by Mark Ward
The engine should drop right in. The transmission is correct, you need to
change the engine wiring a bit though...
Mark
www.rrunracing.com
>Ben
FREE COLLEGE MONEY
Need EJ20 parts...
Posted: Sun Sep 30, 2001 3:44 pm
Yep...the engine bolts right in to the stock mounts...bolts right up
to the stock tranny, and the leg. turbo tranny is on of the stronger
suby man. trannies, so that good. I am using all the stock leg.
turbo ECU and engine manegment...
Micum
> Ben
FREE COLLEGE MONEY
