Al-I had a `trans chip` that tied in thru the ECU to increase line pressure among other things. The one I had returned had cost me $235 & was supposed to work on the early (90-94) 4EAT trans. The credit was to be applied to a `series 2` chip that would work in our cars. I hope they have the decency to either ship it or return my money. Good luck to all of us---ROD (AZ.)
----- Original Message -----
acroxford@hypermall.net
To:
BC-BFLegacyWorks@yahoogroups.com
Sent: Saturday, October 20, 2001 10:25 AM
Subject: [BC-BFLegacyWorks] Re: legacy engine cuts out
Hi Rod,
That is bad news because this guy had nothing to do with sales or the
money, he along with myself are also out quite a bit. The company is
gone and I don't know what the settlement will be. I will keep looking
and if I see anything promising I will let you know. What is it that
you ordered ? ( if you care to tell).
AL (CO)
--- In BC-BFLegacyWorks@y..., "Rod Grosvenor" <roderic@c...> wrote:
> Al-thanks for checking out the situation. They have my $ in cash,
not a credit card. But if the guy is honorable & could use some good
customers to start out with, he`ll handle my $ as credit toward other
item(s). Time will tell---ROD (AZ.)
> From: acroxford@h...
> To: BC-BFLegacyWorks@y...
> Sent: Friday, October 19, 2001 8:56 PM
> He is just starting to move in to a place sometime this week and
will
> be manufacturing parts and accessories and will be only doing
> wholesale but I am going to see if I can work something out if
someone
> wants a part. I would have your credit card company charge back
the
> amount that you paid them on your order as I think it may be some
time
> before there would be any money from the company.
> AL (CO)
wrote:
> > Al-could you give me the name of the person from JC Sports who`s
> starting their own business? Do you have a phone number? It would
sure
> help me as I have a trans chip on order & am wondering what`s
going to
> happen to my money. Thanks for any help---ROD (AZ.)
> > Sent: Monday, October 15, 2001 6:38 AM
> > Sure does, the wiring on a few models was found to be a little
> > different I will try to find out what ones they were I am
pretty
> sure
> > that they were Imprezas. I will also try to find a source for
you.
> One
> > of the people that worked for JC Sports is starting a new
business
> of
> > his own and may be able to furnish them. I am glad to see this
as
> he
> > is the person that made all the neat stuff for the turbos.
> > AL(CO)
> > --- In BC-BFLegacyWorks@y..., "Bill Covert" <boybill@m...>
wrote:
> > > Al, does this fuel pump bolt right in as a direct
replacement
> for
> > the OEM
> > > unit? BillC
> > > From: <acroxford@h...>
> > > To: <BC-BFLegacyWorks@y...>
> > > Sent: Sunday, October 14, 2001 64 PM
> > > > We found that on a few aftermarket turbo setups that they
were
> > weak on
> > > > the top end and that the fuel pressure would drop. This
means
> that
> > > > volume is involved also. The math on it looks like the
factory
> > gave a
> > > > fuel pump to us that would just meet the demands of the
emgine
> so
> > if
> > > > you have done or are thinking of any mods a high volume
pump
> might
> > be
> > > > in order. I confirmed this on my Legacy turbo in a '95
> Imprezza
> > the
> > > > other day I replaced the pump and really picked up some
hp.
> Mine
> > was
> > > > made by Walbro and is rated at 255 lph.
> > > > Al(CO)
> > > > --- In BC-BFLegacyWorks@y..., "Daniel Wilson"
> <daniel.wilson@d...>
> > > > wrote:
> > > > > You can't test a fuel pump like that, because they will
work
> > fine
> > > > > until you put load on them. You will need to get someone
to
> > check
> > > > the
> > > > > fuel pressure.
> > > > > Dan
> > > > > --- In BC-BFLegacyWorks@y..., rjjmoss@y... wrote:
> > > > > > I have an 1989 legacy rs . problem I,m having is
driving
> > along
> > > > > > nicely when motor dies. will run roughly on idle but
dies
> if
> > given
> > > > > > any throttle. I suspect fuel problem and have removed
> petrol
> > pump
> > > > > > and tested. seems to work well when wired direct to
> battery.
> > > > > > couldn,t seem to get power at p/pump wiring connection
> with
> > > > ignition
> > > > > > switched on . replaced p/pump relay under dash and
and
> car
> > > > started
> > > > > > and ran well for 4 or 5 miles. then died again.
> > > > > > towed it home and thats where I,m at. appreciate any
> > suggestions.
> > > > > > thanks Rob
> > > > To unsubscribe from this group, please send an email to:
> > > > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> ADVERTISEMENT
Service.
zZz <
http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
http://rd.yahoo.com/M=213858.1650662.31 ... .tf?s=5085>
http://us.adserver.yahoo.com/l?M=213858 ... =251659675>
zZz <
