It will be on your vin tag, It will be at the bottom of the pillar between the front and rear doors on the drivers side. Open the door and lean down and you should see it. Little aluminum plate. Will have your manufact date on it.
Josh Colombo
jcc189@psu.edu < mailto:
jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
nissans14@yahoo.com]
Sent: Tuesday, October 23, 2001 42 PM
To:
BC-BFLegacyWorks@yahoogroups.com
Subject: RE: [BC-BFLegacyWorks] Re: Anyone ever experience this?
i have a 129,000 miles I'll do a reset... thats a good
idea... I'm praying though that this is the
probablem... anyone know how to check what month and
location my car was made?
--- Josh Colombo <
jcc189@psu.edu> wrote:
> Before you go and replace this stuff. What I would
> suggest is resetting
> the ECU, drive the car for a little bit, then check
> the codes again. If
> you get the same codes again, you know you have a
> problem with that
> particular sensor and it wasn't a fluke.
> How many miles are on the car? The O2 sensor
> personally I'd just go
> with the dealer one. They're goin to run you around
> 100 bucks for a
> good 3-wire one. I went dealer for my 90 because
> there was 2 different
> models during the 90 model year, depending on when
> the car was manufact.
> Josh Colombo
jcc189@psu.edu>
> From: Nissan-Subaru [ mailto:
> Sent: Tuesday, October 23, 2001 3:12 PM
> To:
> Subject: [BC-BFLegacyWorks] Re: Anyone ever
> experience this?
> I check my ecu for codes today and I got 32 and 21
> Oxygen sensor and water temperature sensor
> O2 sensor from the dealer is $130
> Bosch o2 sensor is $85
> No name o2 sensor is $80
> The bosch book only list it for 1992-1994 as being a
> turbo. How do I check what month my car is? Also is
> there anyone out there that knows where to get it
> for
> cheaper? Do you think the problem I described before
> is the effect of a bad 02 sensor?
> Thanks
> John
> 91 sport sedan
> --- Nissan-Subaru <
nissans14@yahoo.com> wrote:
> > Anyone ever encounter this problem on a turbo
> > legacy
> > Poor gas milage about 200miles per tank
> > Which is the same thing before and after a UR
> pulley
> > install
> > It also seems like it doesnt always want to lay
> the
> > power to the ground sometimes it picks up and
> goes
> > and other times it revs the same but its just not
> > being laid to the ground I personally think its
> > some
> > sensor but Im not sure on what.
> > I have new plugs and wires, pcv valve, fuel
> filter,
> > fresh oil change, new belts, UR pulley. (Thats
> all
> > the engine related stuff Ive done recently)
> > Any ideas?
> > __________________________________________________
> > Do You Yahoo!?
> > Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
> > To unsubscribe from this group, please send an
> email
> > to:
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Do You Yahoo!?
> To unsubscribe from this group, please send an email
> to:
Do You Yahoo!?
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
ADVERTISEMENT
http://rd.yahoo.com/M=213858.1650662.31 ... .tf?s=5085>
http://us.adserver.yahoo.com/l?M=213858 ... =243328938>
zZz <
http://docs.yahoo.com/info/terms/> .
