Boost gauge Q
Posted: Sat Oct 27, 2001 1:40 pm
by Nissan-Subaru
my boost gauge came with a 1/8 clear plastic tube....
i don't understand how its supposed to stay together
with the fittings... are you supposed to flare the
ends by stretching it or something? someone get back
to me ASAP! please
--- Samuel Barrett <LEVATHIAN@sprintmail.com> wrote:
> Mee too. '91
> -----Original Message-----
> From: Gordie Hatt
> [mailto:gordhatt@hfx.eastlink.ca]
> Sent: Saturday, October 27, 2001 4:45 AM
> To: BC-BFLegacyWorks@yahoogroups.com
> Subject: RE: [BC-BFLegacyWorks] Re: 4wd to Fwd.
> someone???
> my 91 has a fwd plug
> Gord
> From: ssspoon@aol.com [mailto:ssspoon@aol.com]
> Sent: October 27, 2001 66 AM
> Subject: [BC-BFLegacyWorks] Re: 4wd to Fwd.
> someone???
> Think I just read somewhere that the 4wd disable
> plug is on 92-94
> Do you have a 91?
> Ssspoon
> To unsubscribe from this group, please send an
> email to:
> BC-BFLegacyWorks-unsubscribe@egroups.com
> Your use of Yahoo! Groups is subject to the
> Yahoo! Terms of Service.
> ADVERTISEMENT
> email to:
> Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
Monitoring Service trial
http://us.click.yahoo.com/Gi0tnD/bQ8CAA ... /XoTolB/TM
Boost gauge Q
Posted: Sat Oct 27, 2001 3:15 pm
by Jay Erlenbach
What kind of gauge do you have? If it's autometer then
it is exactly the same type of thing mine was. it does
flare when you use the little what look like brass
beads inside of the fittings, (take the hat and push
it on the tube then one of the beads then the bottom
part and tighten, only do this once though because it
ruins the beads if you take it apart. To plumb it into
the car you will need other brass fittings that have
the regular push on type thing for rubber hose. I
found a set up at Menards, but I think any DIYer type
store that has a plumbing section should have them.
Hope this helped, if not you can yell at me
Jay Erlenbach
'92 Legacy Turbo Sedan (US Spec)
> tube....
> to me ASAP! please
> > Mee too. '91
> > From: Gordie Hatt
> > someone???
> > Gord
> > someone???
> disable
> > plug is on 92-94
> > Do you have a 91?
> > Ssspoon
> > email to:
> > ADVERTISEMENT
> > email to:
> Yahoo!
> > Terms of Service.
> Do You Yahoo!?
Do You Yahoo!?
Boost gauge Q
Posted: Sat Oct 27, 2001 3:52 pm
by Nissan-Subaru
ok i got it installed.... and it was showing just a
little over 8psi but after maybe 6 hard passes it
fluctiats alot (fast vibration 0-8psi depending on how
hard i push... whats causing this? it was working well
for a few runs? everything inder the hood is nice and
tight?
--- Jay Erlenbach <legacy_productions@yahoo.com>
> then
> does
> it
> into
> type
> Jay Erlenbach
> > tube....
> together
> back
> > to me ASAP! please
> wrote:
> > > Mee too. '91
> > > From: Gordie Hatt
> Fwd.
> > > someone???
> > > Gord
> > > someone???
> > disable
> > > plug is on 92-94
> > > Do you have a 91?
> > > Ssspoon
> an
> > > email to:
> > > ADVERTISEMENT
> > > email to:
> > Yahoo!
> > > Terms of Service.
> > Do You Yahoo!?
> Do You Yahoo!?
Do You Yahoo!?
Boost gauge Q
Posted: Sat Oct 27, 2001 8:51 pm
by Dave C
I'm seeing a continuation of a really nasty trend here: boost
that's not measuring up.
I have a feeling that it's the stock solenoid.
One of the first, and most inexpensive mods for a turbo owner
should be some kind of MBC. They work better and replace a
part that's at least 7 years old, up to 10 in some cases.
Am i on to something?
--- In BC-BFLegacyWorks@y..., Nissan-Subaru
> tight?
