EJ16 info
Posted: Thu Apr 03, 2003 5:12 am
by mile hi
Anyone have a diagram or ECU wiring info on a EJ16 motor? I am selling a chip on one and want to check the wiring.
AL(CO)
al@iwtu.net
Posted: Thu Apr 03, 2003 5:54 am
by ciper
I didnt realize an ej16 existed. Are you sure you dont mean 1.8l?
Posted: Thu Apr 03, 2003 7:07 am
They did make an EJ16. Some unfortunate Imprezas got it.
Al, I'd expect that the pinouts would be almost identical to the other EJ-series 2-channel ignition ECUs in that model year car. Do the connectors match up (as in number of pins, housing color, etc)?
Posted: Thu Apr 03, 2003 3:18 pm
by mile hi
Not sure about the plugs the car is in Singapore and I thought it would be nice to have the diagram if possible. I wonder if it may be the same ECU as the EJ18.
AL(CO)
al@iwtu.net
Posted: Thu Apr 03, 2003 3:52 pm
by mile hi
If anyone should come across any information on this I would also like to know the Bore and stroke, if it is a de-stroked 1.8 I might want one or at least the crank. I have a set of mechanical adjustable roller rocker arms and with better valve springs I would try and get it to 10,000 rpm the best I have done so far is 8500 rpm with a NA 2.2.
AL(CO)
al@iwtu.net
Posted: Thu Apr 03, 2003 4:30 pm
Oh, I misunderstood... I thought you were trying to sell him an ECU, not a piggyback chip.
I doubt the ECU would be the same as the EJ18's but the wiring might. It's weird... Subaru did sometimes use the exact same connector hardware with wildly different pin assignments (like compare the 1995 Legacy to the 1996 Legacy). Seems like a dumb thing to do.
But then again, all the ECUs with the same connectors as our BC/BF Legacies have almost the same pinouts (aside from aspiration differences and ignition system differences).
And apparently I'm told some BC Legacies in Asia had the EJ16 too. That might imply the pinouts are nearly the same as ours.
You could just have him take a continuity tester to the relevant sensor pins and pins on the ECU connector...
Posted: Thu Apr 03, 2003 10:42 pm
by mile hi
I will have to agree that Subaru does weird things the 95-96 Legacy is an example all they did was flip the connections over left to right for no gain.
This Impreza has been converted to a EJ22 n/a engine and they are trying to get a diagram for me.
AL(CO)
al@iwtu.net
Posted: Fri Apr 04, 2003 2:06 am
by -K-
If you get an EJ16 to 10,000 rpm, I want a sound clip! What is holding you to only 8500?
Posted: Sat Apr 05, 2003 12:32 am
by mile hi
I thought that the valves were starting to float but I now am pretty sure that I was running out of fuel. The engine was a 2.2 in a '87 3 door coupe and all it had was a RX fuel pump. The 1.8 likes to rev even better so I thought that a 1.6 would be a screamer.
AL(CO)
al@iwtu.net
Posted: Sat Apr 05, 2003 3:52 am
by ciper
I want to read more about the ej16. Anyone have info?
Posted: Sat Apr 05, 2003 4:06 pm
by mile hi
I should have the information on the electronics on Monday it is being faxed to me by a servicer in Singapore. He has expressed a desire to become a dealer of our products so I should be able to get more information on the engine.
AL(CO)
al@iwtu.net
Posted: Thu Apr 10, 2003 4:00 am
by ciper
AudioFan on the NASIOC forums has a 1.6, I pm'ed him to come over
Posted: Thu Apr 10, 2003 1:03 pm
by AudioFan
I have a 1.6 L Impreza, FWD, I bought the ProECM chip and I have it installed in my car. My car is a 1998 but is has MAP not MAF, Just in case, Here are the diagrams.
Hope this helps, anything else about the 1.6 EJ just ask, I don´t know much, But I´ll try to help
Posted: Thu Apr 10, 2003 2:12 pm
Posted: Thu Apr 10, 2003 11:55 pm
by AudioFan
And here is some info of the car. If you need help with the spanish just ask.
Posted: Fri Apr 11, 2003 1:16 am
