OBD Stuff...
Posted: Fri Dec 28, 2001 3:22 am
by Brian White
Question...Are OBD 1 scanning/diagnostic tools
worthwhile? If so, what can be done with them besides
clearing the CEL? I know you can get some information
as to why the code is displayed, but what value does
this have? Thanks for all the info. In the last few
weeks I have learned a lot more about my own car. I
appreciate the help.
-Brian
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
OBD Stuff...
Posted: Fri Dec 28, 2001 7:40 am
by Josh Colombo
Personally, OBD 1 scanner stuff probably really isn't that good an investment. With the OBD 1 computers you can check the diagnostic codes yourself, clear them, and so forth. Maybe the only other thing you would get with a scanner would be see some inputs from sensors when car is running.
Check out my site for info on how to pull the codes/reset ecu and stuff. www.surrealmirage.com/subaru/subaru.html
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, December 28, 2001 2:17 AM
Subject: [BC-BFLegacyWorks] OBD Stuff...
-Brian
Do You Yahoo!?
OBD Stuff...
Posted: Fri Dec 28, 2001 12:00 pm
by Rod Grosvenor
Brian-In addition to what Josh gave you: the scan tool will give you what is called a "diagnostic tree" to follow while attempting to eliminate any problems. It will highlight any specific codes relative to each screen you choose on the scanner. It`s very useful, expensive & usually relagated to dealerships.---ROD (AZ.)
----- Original Message -----
Sent: Friday, December 28, 2001 1:16 AM
-Brian
Do You Yahoo!?
ADVERTISEMENT
<http://rd.yahoo.com/M=216105.1806326.33 ... =posthol01>
<http://us.adserver.yahoo.com/l?M=216105 ... =142620367>
OBD Stuff...
Posted: Sat Dec 29, 2001 9:40 am
by milehial2000
It probably depends on the version of OBD that you have but we are
trying several data logging systems on some later models most with OBD
2 and are having good results and getting a lot of information. You
might want to check on the web or contact me Wed. and I will give you
a few leads to try.
> -Brian
> Do You Yahoo!?
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA ... /XoTolB/TM
