Please if anyone remembers who is selling a formed aluminum turbo outlet duct please turn me on.
Looked kind of like a letter "J" and transitioned from a Subaru turbo outlet cross section into a 3 inch circular cross section.
Think I may have seen it on "The Backyard Boys" website, but that isn't working now.
Where is turbo outlet duct link?
Brett Middleton
Larry you mean from the turbo to the intercooler?
milehial2000
Larry if you do mean the turbo to intercooler duct I need one also but
my turbo is going to have a 2 inch outlet as I have decided now when
all is done I am going to use the TDO5 from the WRX.
ssspoon@aol.com
No Brett, from the turbine outlet to the downpipe;
I found it. From Air Power Systems.
http://www.airpowersystems.com.au/wrx/housing.htm
Looks pretty good to me for use on a Garrett turbo with an external wastegate, if the flange could be adapted to fit. Trouble I have with it, is it's supposed to be for IHI turbos, all I think with internal wastegates. I don't like mixing internally wastegated gas with the normal turbo flow that close to the turbine outlet.
Gary Grahn
Larry,
You could always weld the internal WG flapper shut and convert to an external off the up pipe....
Brett Middleton
ahh yes ok
our exhaust has a SPLIT outlet so this may assist you, here is a new link to
the data
http://www.mrtrally.com.au/performance/brochures.htm
select "exhausts"
the data
select "exhausts"
