Turbocharging the EJ-22 NA
If anyone here has experience turbocharging the EJ-22 NA, please send
me an e-mail. I'm making "use" of a recent accident I was in as an
excuse to start playing with my car... inspired by one of those sick
Liberties in New Zeland, plans are in the works
Rod Grosvenor, has done this. He got a kit from www.forcedairtech.com He really likes it. I'm probably going to turbo my 90 N/A legacy next spring/summer (2003) I will probably use the same shop/people that Rod used. This summer's project is a tranny swap
I've seen Rod's setup in person, and it's nice. I didn't get a
chance to ride, but i hear it's brisk.
Done right, you can turbo anything
I was thinking of using the STi (IVHF?) ball bearing turbo. I
suppose I really need to know all the parts that go into a kit,
ensuring that I have everything I need.
Along the same lines, what's the diameter of the MAF? I'm thinking
of using the Prodrive trick of doubling a turbo with a ram air.
Thanks though, I'll check out what Forced Air Technologies has!
This is from Forced Air's site
Frequently we are asked what the kits contain:
1: The Turbo Charger for the Stage 1 and 2 kits is a T3-TO4E. The stage 3 kit is a GT25
Dual Roller Bearing Turbo.
2: The up pipe (2 1/8 inch) and down pipe
(2 1/2 inch) including a 2 1/2 inch high flow
catalytic converter section which includes 2
O2 sensor ports is included.
3:The Stage 1 kit comes with the pressure side
manifold from the Turbo to the intake manifold and the air intake manifold to the Turbo Charger.
4: The Stage 2 and 3 kits come with an intercooler and all of the piping to install it.
5: All kits come with all of the oil supply lines to the Turbo and the Turbo oil return line.
6: All kits come with a fuel pump.
7: All of the Turbo kits come with an RRFPR
(rising rate fuel pressure regulator), a blow
off valve, and a voltage clamp for all of the
speed density equipped cars. They come with
a K&N air filter.
8: They come with all of the necessary hardware and full color photo instructions
to install.
9: All of our kits contain everything to Turbo Charge your vehicle. The only thing that the
customer has to supply is a minimum of 2 1/4
inch exhaust system from the catalytic converter and back. The factory exhaust is
very inadequate.
a K&N air filter.
to install.
very inadequate.
The stock n/a MAF inside diameter is 68 mm and there is a small
beveled ring inside of it that narrows down to 60mm. What is this
doubling with ram air? did I miss something?
IIRC, in both the WRX P1 and the WRX UK2000, Prodrive relocated the
intercooler to the front, right behind the bumper/under-spoiler and
moved the air filter so that it was sitting right behind the hood
scoop. That's what I meant.
Hello-I`m Rod with the A/M turbo kit on my NA motor; love it! I have some other suggestions to upgrade your set-up that`ll really make a difference. When you contact Forced Air, tell him Rod referred you for a bett
Hey Rod, how much did this project cost you, in total? I'm interested
in doing this to my N/A but my funds are running low, so I need to
know how much I should cut back my other expenses...
So these forced air tech guys have a kit specifically for the EJ22 NA
motor that will bolt straight on? You speak of inspiration from some
people in NZ doing the same thing. Is there a similar company in New
Zealand (its where I live).
I have a 90 Legacy Gx Wagon with an EJ22. Its a bit rough but i
bought it intending that it would be a bit of a fix up. If you bolt
a turbo on the engine I'm guessing there is a fair bit of work to do
further down the drivetrain?
Anyway its all a bit far down the track at the moment but I'd like to
pack as much knowledge in as I can before I go ahead.
Iain-A realistic total to do it right would be around $3500.00. This includes the ignition, exhaust, tuning, etc. to bring it all together. If you want MY total & what I`ve done, post me back.---ROD (AZ.)
Hi-Visit www.forcedairtech.com & see what he has to offer; send an e-mail with any specific requests. I have`nt had to beef up any drivetrain components with the Stage 1 kit with the Stage 111 turbo & I just love the kit. It`s a bolt-on except for the exhaust hook-up. Good luck---ROD (AZ.)
