to change. To check the fuel pump pull the electrical plug and check for
12V from the Relay.If there is no voltage don't panic the relay only
trips if it has a load to start. Pull pump from the tank(have some plugs
ready for the hoses, fuel will run. Use a 12V jumper wire (+ and -) find
the wires that go to the pump(I wouldn't be in the car when you test)
just touch the connections if there is nothing Its DEAD.
(Southwestern,WA{Brooklyn})
