Subar legacy rs type ra
Posted: Tue Apr 08, 2003 4:11 am
by Phil
1st STI
Anyone else got one? would be nice to compare.
Posted: Tue Apr 08, 2003 4:29 am
by subaruguy
I wish I had one!!!
Posted: Tue Apr 08, 2003 1:57 pm
by boostjunkie
Posted: Sun Jul 27, 2003 9:03 pm
by rB5
I'm just dragging this out of the depths to see if anyone has more info. on the STi RA Legacies, or the Prodrive edition. Mainly how they differ to the U.S. spec Legacy Turbos.
-B
Posted: Sun Jul 27, 2003 9:32 pm
by LegacyT
Did they have any significant power increase over the standard Liberty RS? Or was the difference between the two mainly in the suspension?
Mark,
Posted: Mon Jul 28, 2003 4:07 am
If someone wants to try to make some sense of the translation, this page might be of use:
http://www.decal-co.com/out-flat/variation-e.html
Posted: Mon Jul 28, 2003 4:41 am
by mTk
There are a few pics around if you search google.
MK
Posted: Mon Jul 28, 2003 4:11 pm
by Brat4by4
RS-RA is a very limited production model that was hand built to the specs they used on the 100,000km record attempt vehicle. It got forged pistons, stronger connecting rods, ported and gapped intake & exhaust ports, some stiffer bushings & spring/damper rates, a variable ratio power steering box, hand balanced: crank, flywheel, & clutch cover, along with some special color engine components.
If you could find one of these wrecked, it would be a virtual goldmine of valuable hardcore Legacy parts. Everything above was gleaned from the article that vrg3 posted.
Posted: Mon Jul 28, 2003 8:45 pm
by Grant
So the RS-RA engine is the EJ20G according to that article and put out 20 hp more than the normal turbo engine. I seem to remember someone on here having that engine in their Legacy.
Posted: Thu Jul 31, 2003 10:46 pm
by rsstiboy
the only diffrence from this engine to the aus spec liberty one is, the RA has forged pistons and rods, same VF12 turbo, yellow top injectors, and it runs 16-17psi standard!!
Posted: Fri Aug 01, 2003 1:39 pm
by magicmike
Posted: Tue Aug 12, 2003 8:40 pm
by Bobalouy
I found this thread because I found this webpage, with some nice pics. Im pritty new here so I hope they havnt already been posted.
I like the wing, is this a subaru part?
Anthony C
Posted: Tue Aug 12, 2003 9:14 pm
by Brat4by4
maybe, but I don't think that wing came with the car, though.
Posted: Wed Aug 13, 2003 2:56 am
by georryan
You guys are going to like this!
http://www.turnermotorsport.co.nz/car_subaru.html
http://www.turnermotorsport.co.nz/photos02_a.html
I'm looking for more.
I think I may have some more desktop photos from those links.
Posted: Wed Aug 13, 2003 11:00 pm
by Bobalouy
looks like it is a lancer wing
Anthony C
Posted: Thu Aug 14, 2003 12:10 am
by eastbaysubaru
That's what I thought the first time I saw it, but without seeing the center vertical section I wasn't going to call it
-Brian
Posted: Thu Aug 14, 2003 1:52 pm
by Brat4by4
Lancer Wing ?!?
That's.... that's... why did he do that?
Why
Posted: Fri Aug 15, 2003 2:36 am
by SubbyRS
It's not a Lancer wing, looks more like an aftermarket cheapie that's readily available for the "boy racer" fraternity here in New Zealand......
The Legacy that owns it is a "GT 4WD" (according to the badge), which means EJ20G, VF-10 turbo & 4EAT trans......The RS sedan has the same EJ20G but a bigger VF-8 turbo & 5spd trans only.....
Posted: Fri Aug 15, 2003 3:30 am
by czo79
How does the VF10 compare in size to the turbo on the US legacy turbo sport? I know its another rhb5 but I can't remember whether the us is a VF12 or 11 or what. Anyways, which is bigger?
thanks
micum
Posted: Fri Aug 15, 2003 4:08 pm
by 91White-T
I think most of the US cars have the VF10, I know mine does...
Posted: Fri Aug 15, 2003 7:16 pm
by czo79
Damn! And here I was thinking I was all special with a bigger turbo than most of you guys...way to cut me down to size!
Micum
