Can I replace air suspension with conventional struts?
Posted: Thu Oct 31, 2002 4:03 pm
by dsc
The air suspension on my friend's 1996 Legacy wagon has gone haywire. I haven't seen it, but I am told the car jumps up and down eratically. The car is due for struts anyway, so I was thinking that I would ditch the air suspension and install conventional struts and strut tops. Are there any reasons why this is a good or bad idea?
Posted: Thu Oct 31, 2002 6:31 pm
by DLC
I've recommended that most people with failing Air suspensions do this. It's really pretty simple to just replace them.
You'll probably need to go to a salvage yard and just buy the entire struts assembly: top mount, top hat, spring and strut, then depending on the condition of them, possibly get some KYB GR2 replacement struts.
As for the rest, air lines and pump, it can be removed as much or as little as he feels necessary.
Posted: Thu Oct 31, 2002 6:40 pm
by ciper
dsc: I have done the swap on my legacy. However I seriously doubt your freind has air suspension. More likely he has standard suspension and they are very worn becuase he doenst take care of the car.
I had always though air suspension stopped in 92-93.
