engine shaking
engine shaking
I recently finished installing a EJ20G turbo Liberty RS engine into
my '95 EJ18 Impreza L using the EJ18 stock ECU. I kept the throttle
body from the EJ18 because the throttle position sensor and idle air
controller connectors were slightly different. All of the other
sensors on the EJ20 engine plugged into the EJ18 ECU harness. The
engine starts, and runs too, but the engine shakes alot. The entire
engine shakes, not just a small vibration, its a full fledged shake.
Has anybody experienced this problem on your Libery RSs? The computer
is displaying error codes 34 and 36...I haven't been able to find
what these mean yet. What is causing this shaking?
Monitoring Service trial
http://us.click.yahoo.com/ACHqaB/bQ8CAA ... /XoTolB/TM
engine shaking
Hmmmm I might have an answer tommorow I will be getting a '93 Impreza
with a EJ20G engine in it from a out of town dealer and it runs very
poorly and he wants me to straighten it out and get it running
well. They have been working on it for some time. What did you do to
run the coils? The 1.8l had a different coil system and the 1.8 ECU
will not run the EJ20 four coil system and that would explain the
shaking.
AL(CO)
computer
Access Your PC from Anywhere
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/lmECdA/6XkDAA ... /XoTolB/TM
shaking.
AL(CO)
computer
engine shaking
All I did was use the EJ18 ignition coil (a single unit) and spark
plug wires. The spark plugs screw into place and the wires were just
barely long enough. Could it be a timing problem? Thanks
Impreza
very
to
ECU
> shaking.
> AL(CO)
into
throttle
air
entire
shake.
> computer
Impreza
very
to
ECU
> shaking.
> AL(CO)
into
throttle
air
entire
shake.
> computer
engine shaking
Surely the answer is in the question - stock EJ18ECU?!!
----- Original Message -----
Sent: Monday, January 28, 2002 4:53 PM
Subject: [BC-BFLegacyWorks] engine shaking
engine shaking
Doesn't the EJ20 use direct ignition. The coil is right there at the spark plug. I'm sure the coil output for the 1.8 is not beefy enough.
-----Original Message-----
Sent: Mon 1/28/2002 12:34 PM
Cc:
Subject: [BC-BFLegacyWorks] Re: engine shaking
Impreza
very
to
ECU
> shaking.
> AL(CO)
into
throttle
air
entire
shake.
> computer
Cc:
Impreza
very
to
ECU
> shaking.
> AL(CO)
into
throttle
air
entire
shake.
> computer
engine shaking
I had to think about this a bit there is no easy way out I am afraid.
The problem is that the 1.8 and the 2.0 use different tpyes of
ignition. The 1.8 is a wasted spark or bank fire ignition and the 2.0
is sequential ignition or one plug at a time in a certain order. The
only thing I can think of is the solution that I am using on another
car with the same problem and that is to replace the ECU, harness,
manifold and manifold harness with the same from a EJ25l engine. The
only other alternatives would be a stand alone aftermarket ECU or the
original EJ20l Ecu and harnesses.
AL(CO)
enough.
> Josh
> From: limonoah [mailto:limonoah@h...]
> To: BC-BFLegacyWorks@y...
> Cc:
spark
were just
'93
> Impreza
runs
> very
running
you do
> to
1.8
> ECU
explain the
> > shaking.
> > AL(CO)
engine
> into
> throttle
and idle
> air
other
harness. The
The
> entire
fledged
> shake.
The
> > computer
to find
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
AL(CO)
enough.
> Josh
> Cc:
spark
were just
'93
> Impreza
runs
> very
running
you do
> to
1.8
> ECU
explain the
> > shaking.
> > AL(CO)
engine
> into
> throttle
and idle
> air
other
harness. The
The
> entire
fledged
> shake.
The
> > computer
to find
engine shaking
If one were to replace the wires with those of the same type, replace
the coil with a newer one and use the proper plugs for a turbo
Legacy, it *should* work.
The firing sequence should be the same, Mark has an EJ20 in his
Legacy Turbo with the stock ECU and no problems like this.
afraid.
2.0
The
another
The
the
> AL(CO)
It's Easy. It's Fun. - Free Download.
http://us.click.yahoo.com/kmECdA/7XkDAA ... /XoTolB/TM
afraid.
2.0
The
another
The
the
> AL(CO)
engine shaking
The turbo Legacy ECU could be tried chances are the 1.8 will run it
lean with no knock sensor. Thats one reason that the turbo models
suffer from poor gas milage the factory programmed a rich mixture in
to them to prevent problems.
--- In BC-BFLegacyWorks@y..., "legacycentral" <legacycentral@y...>
replace
> Dave
> afraid.
> 2.0
> The
> another
> The
> the
> > AL(CO)
replace
> Dave
> afraid.
> 2.0
> The
> another
> The
> the
> > AL(CO)
engine shaking
I would tend to use the EJ20G computer. The EJ22T ECU does not work with the EJ20G, at least if you use the EJ20G sensors. I use the EG20G computer in mine, it was very easy to swap over. You need to swap over the 4 wires for the ignition and route these to the front left of the engine, to the wiring harness. As brought up before, there is also a difference in programming on these cars as well. I did have the extreme shaking as well and I sourced it to ignition. You will get better performace out ofthe EJ20G for sure.
Do you have the wiring diagram for both motors? I have the EG20G wiring harness diagram if you want a copy of it. Lay it out with your old motor to find the differences. Another reson for me to use the stock ECU was so I can go up to the Possum ECU from MRT as soon as I have the $$$. you can get a piggy back model or the full swap computer, this gioves you wicked control over your motor and a substantial increase in power.
Mark
www.rrunracing.com
Sent: Monday, January 28, 2002 114 AM
Subject: Re: [BC-BFLegacyWorks] engine shaking
ADVERTISEMENT
<http://rd.yahoo.com/M=219350.1849047.33 ... g22lp.tmpl>
<http://us.adserver.yahoo.com/l?M=219350 ... =424753796>
Mark
www.rrunracing.com
ADVERTISEMENT
engine shaking
Mark I would like to have a copy on those wire diragarm before my
mechanic install my motor, could you send me one???
Ben
Ben
engine shaking
Could I get a copy of the wiring diagram also Mark ? I have done
this conversion before using the EJ25 ECU with a few mods and it works
well but this was sometime ago and a diagram of the EJ20G would help I
am sure. Also Do you have a source for the EJ25 ECU and sensors ?
AL(CO)
with the
computer in
wires for
wiring
programming on
sourced it
sure.
wiring
motor to
so I can
get a
control
> Mark
> www.rrunracing.com
> From: Kam [mailto:kam@s...]
> From: limonoah
into
throttle
air
The
entire
shake.
computer
find
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Service.
AL(CO)
with the
computer in
wires for
wiring
programming on
sourced it
sure.
wiring
motor to
so I can
get a
control
> Mark
> www.rrunracing.com
> From: limonoah
into
throttle
air
The
entire
shake.
computer
find
Service.
Service.
engine shaking
works
I
> am sure. Also Do you have a source for the EJ20G ECU and sensors ?
> AL(CO)
work
> with the
> computer in
> wires for
the
> wiring
> programming on
> sourced it
> sure.
> wiring
> motor to
was
> so I can
can
> get a
> control
> > Mark
> > www.rrunracing.com
> > From: limonoah
> into
> throttle
idle
> air
other
> The
> entire
> shake.
> computer
> find
> Service.
> Service.
works
I
> AL(CO)
work
> with the
> computer in
> wires for
the
> wiring
> programming on
> sourced it
> sure.
> wiring
> motor to
was
> so I can
can
> get a
> control
> > Mark
> > www.rrunracing.com
> > From: limonoah
> into
> throttle
idle
> air
other
> The
> entire
> shake.
> computer
> find
> Service.
> Service.
engine shaking
Have you checked fuel delivery yet Mark ? I have found that when I
installed a EJ22t in place of the EJ18 the fuel pump just wasn't up to
it. And when I installed a 255lph pump I could feel the difference.
This might some thing to keep in mind on all conversions it seems that
the factory gave us a fuel pump that was just adequate for the engine
and that was all.
AL(CO)
with the
computer in
wires for
wiring
programming on
sourced it
sure.
wiring
motor to
so I can
get a
control
> Mark
> www.rrunracing.com
> From: limonoah
into
throttle
air
The
entire
shake.
computer
find
Service.
Service.
and that was all.
AL(CO)
with the
computer in
wires for
wiring
programming on
sourced it
sure.
wiring
motor to
so I can
get a
control
> Mark
> www.rrunracing.com
> From: limonoah
into
throttle
air
The
entire
shake.
computer
find
Service.
Service.
engine shaking
Thanks to everyone for your responces/suggestions! Your right,
ideally I would be using the original ECU for the EJ20G however the
wiring harness is in terrible shape. The engine section of the
harness is mostly in tacked but some of the wires are cut and are
not useable. On the ECU end, the wires are cut an inch out of the
ECU. I have had no luck in finding an accurate wiring diagram for
any of the EJ20 models, so if you could possibly send me a copy, I
would be gratefull.
If I try to run the engine with the EJ18 ECU, is there a significant
difference in power of the ignition coils of the 1.8 and the 2.5? If
I used the EJ25 coil, would I still have the bank fire\sequential
fire ignition problem?
Noah
work with the
computer in
wires for
the wiring
programming on
sourced it
sure.
wiring
motor to
was so I can
can get a
control
> Mark
> www.rrunracing.com
Full setup in 2 minutes! - Free Download
http://us.click.yahoo.com/pmECdA/2XkDAA ... /XoTolB/TM
would be gratefull.
Noah
work with the
computer in
wires for
the wiring
programming on
sourced it
sure.
wiring
motor to
was so I can
can get a
control
> Mark
> www.rrunracing.com
engine shaking
I don't think you will have much luck trying to use the EJ18
ECU for several reasons including that it has been tried
unsucessfully a few times.But using the EJ25 or the EJ20G ECU and
harness will cure the ignition problem. We have a Legacy wagon and a
Imprezza running with the EJ25 harness and ECU on the EG20t and they
are running very good. The EJ25 ECU is driving the stock coils on both
cars but we switched to the EJ25 manifold to get the proper sensors
for the ECU. I have that copy of the EJ22t diagram that you E-mailed
me about a while ago it is a copy of a copy and does not scan well so
if you would like to e-mail me your address I could mail it to you and
include the EJ25 diagram also.
AL(CO)
> would be gratefull.
> Noah
> work with the
> computer in
> wires for
> the wiring
> programming on
> sourced it
> sure.
> wiring
> motor to
> was so I can
> can get a
> control
> > Mark
> > www.rrunracing.com
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
AL(CO)
> would be gratefull.
> Noah
> work with the
> computer in
> wires for
> the wiring
> programming on
> sourced it
> sure.
> wiring
> motor to
> was so I can
> can get a
> control
> > Mark
> > www.rrunracing.com
engine shaking
I will get to you tommorow.
Mark
Sent: Tuesday, January 29, 2002 5:43 AM
Ben
Mark
Ben
engine shaking
ok, the files are not that big, they are (ready?) a scan of a printout from
an scan from the shop manual except the EJ20G which was faxed to my crappy
fax machine (personal) that was a scan from a manual and faxed from New
Zealand to here in Canada.
I have scanned them all and coverted to PDF format to conserve space.
Yikes!
I cant scan my EJ20T manual cuz it is in the manual still and I dont have a
flatbed scanner...
hope this helps.
Mark
www.rrunracing.com
Sent: Tuesday, January 29, 2002 6:15 AM
would be gratefull.
Noah
work with the
computer in
wires for
the wiring
programming on
sourced it
sure.
wiring
motor to
was so I can
can get a
control
> Mark
> www.rrunracing.com
Yikes!
flatbed scanner...
hope this helps.
Mark
www.rrunracing.com
would be gratefull.
Noah
work with the
computer in
wires for
the wiring
programming on
sourced it
sure.
wiring
motor to
was so I can
can get a
control
> Mark
> www.rrunracing.com
