Air Water I/C BOV and A/A vs A/W
Posted: Sun Mar 24, 2002 12:17 pm
Q: Does the Air/Water I/C from the good versions of the legacy turbo have a spot for a BOV?
A: yes
Q: what amount of boost can you put through that unit?
A: any amount you want, you have to decide what pressure drop you can live with, as boost goes up, so do pressure losses (essentially same as WRX air-to-air)
Q: restrictions over a top mount air/air from the new WRX
A: more costly, more complex installation, more to go wrong, (active components rather than passive), not good for extended boost applications, harder to find (only made for early 90's Turbo Legacy, Subaru must think the air-to-air is as good or better)
Q: advantages over a top mount air/air from the new WRX
A: for short boost applications, marginally better for street and strip, not so good for track, can be used to supercool for short periods, looks snazzier
Larry Witherspoon
Torrance (Los Angeles)
ssspoon@aol.com
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.33 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =654656398>
A: yes
Larry Witherspoon
ssspoon@aol.com
ADVERTISEMENT
