Has anyone here removed and refurbished their IAC? I've seen postings on other boards about WRXs being able to clean theirs out and replacing it. Will this work with ours? Any thing that I need to watch out for as I attempt to remove and replace the IAC?
Thanks.
I had a IAC code and decided to find a used IAC and clean it and it works just fine. Dont use carb cleaner on it I think i used brake cleaner. The Iac usaully gets gummed up.
