Turbo rear brake identification.
Is there any definate marks I should be looking for if the 22t swapped wagon at my local wrecking yard has turbo rear brakes? Are the front turbo ones different than the ones on my n/a? I know this is probably a simple question but I have no clue how to tell the brakes apart.
Danny
Re: Turbo rear brake identification.
The turbo brakes are ventilated which differs from the solid na brakes.
Jeff
Jeff
also the front rotors are 2 pot, while your n/a is single
