Whats the Best O2 replacement for our car VS Price
Best to get a universal?
O2 Replacement
Re: O2 Replacement
Mostly every here will tell you to stick with buying Subaru OEM. I believe it runs for about 115 online @ 1stsubaruparts.com
Re: O2 Replacement
On my N/A cars, I've used the NTK 24614 sensors from Advance auto parts (looks about $85 right now, same company that makes NGK spark plugs etc). They are plug and play, no having to splice wiring like the universal ones.
EDIT: O-Reilly has the NGK 24614 for $56... but I think the store has to special order it. Amazon it looks like $37 !
Albeit, I have used Bosch universal sensors in other vehicles with success, also. Just depends on if you have the real-estate to have a big block thing that splices the wires together. On an N/A car, there is tons of room above the cat and next to the trans so that's not a problem. Might be tight on a turbo car?
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
