Rest of the video is going to be posted soon. I have to merge some stuff together and edit it. I will explain everything there.kimokalihi wrote:What was the cost of everything? I could look....but it would be nice to just have that info here. I like the video and you should make more of the rest of the install. Did you have to cut anything to mount that heat exhanger in the bumper?
Parts list will be posted along with the vid. Everything together cost me $530 or so. (Military Discount too) Probably would cost everyone else about $550 or so.
inlet and outlet are too small. It won't work. You have to buy a proper heat exchanger.ride_child wrote:what if you take out the ac system and use the exchanger from that as the one for the awic? just thinking...
