Does anyone have a California Emissions turbo Legacy, or...
ciper
Post by ciper »
We have two scenarios:
Subaru made all Legacy Turbo to Califronia emissions
OR
Subaru made California specific Legacy Turbo
I dont have my service manuals with me but I remember that NA Legacy have a difference. It could just be a jumper on the ECU while all other items are the same. Either way Id like to know what your emissions sticker says.
One sticker can be seen in this thread http://bbs.legacycentral.org/viewtopic.php?t=14428
eastbaysubaru
Post by eastbaysubaru »
I think they're all to Cali spec, but I'm not positive. I'll go check my hood right now and get back to you in a few ciper.
-Brian
'04 PSM FXT
Matt Monson
Post by Matt Monson »
That was what I thought but still haven't been home to check the service manual or out to my car to check the tag...I will tell you in the am if you don't already know...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
eastbaysubaru
Interesting. There's no stickers on my hood. None at all. Sorry ciper, no help here unfortunately.
-Brian
'04 PSM FXT
ciper
Post by ciper »
eastbaysubaru: Uh oh. You know what that means right?
The ECU definitely knows whether it's in a California car or a Federal/Canada car.
http://www.graphics.cornell.edu/~v/ecupins
Pin 11 of connector B56 is the "jurisdiction ID."
On California cars, that pin is grounded. On Federal/Canada cars, it is left floating.
As far as I know, none of the emissions control hardware itself differs.
ciper
Post by ciper »
VRG3: So we just short the jumper for smog reasons?
Does anyone have a reader that can verify the function?
To make the car CA-spec, you short that pin to ground, yes.
I don't know anything about how it changes the ECU's behavior.
If you hook up a Select Monitor, it can tell you whether the ECU is in CA mode or Federal/Canada mode.
I've got a select monitor, no cartridge for the turbo legacy though.
ciper
Post by ciper »
Would it be too much to ask for you to check your car, then ground the pin and check again?
I could try it I guess if I have time.
I'll see if things work out this weekend to do it & let ya know.
The Select Monitor cartridges handle both turbo and non-turbo cars.
Ciper - I also have a Select Monitor. What exactly is it you would like to find out?
ciper
Post by ciper »
I want to find out what the ECU says regarding California or Federal, and what change if any grounding the pin makes.
If I can take a "Federal" ECU and ground the pin and make the ODB readout say California that would be great.
If it does state this at all of course.
Matt Monson
I couldn't find anything in my Chilton manual. They suck compared to the Helms, but of course factory is best. Anyways, I looked at the sticker on my hood and it says it meets EPA standards. No CA mention at all. Surprises me that on such a limited production vehicle they didn't just make them all CA compliant for ease of manufacture :?:
Suby Hai!
When you put the Select Monitor in mode FA0, it lights up LEDs to reflect the status of seven switches: IG (ignition switch, determined by Ignition Switch pin), AT (automatic transmission, determined by Transmission ID pin), UD (test mode, determined by Test Mode Connector pin), RM (read mode, determined by Read Mode Connector pin), NT (neutral switch, determined by Neutral Switch pin), PK (park switch, determined by Park Switch pin), and FC (Federal/California switch, determined by Jurisdiction ID pin).
On my car, the FC light is on normally. When I ground the Jurisdiction ID pin, it turns off. I can do this even while the car is running.
You can definitely take a "Federal" ECU and ground the pin. There's no such thing as a "Federal" or "California" EJ22T ECU, just like there's no such thing as an automatic or manual EJ22T ECU. They're just different modes determined by the switches.
ciper
Post by ciper »
Thank you. I knew that different ECU's didnt exist this way, thats why I used qoutes to show that it was an ECU originally installed in a federal car.
Now, does anyone have an OBD reader that can check? Does the ODB reader state California or Federal? If so can you try grounding the pin?
I did the check with the Select Monitor.
eastbaysubaru
I'm not quite sure what not having the stickers means. I assume they came off when the hood got replaced back in '97ish after the accident I got into. What does it really mean though ciper?
-Brian
'04 PSM FXT
ciper
Post by ciper »
Eastbaysubaru: I was going to say the hood was replaced, and this is usually because the car was in an accident. If you knew about an accident already then its a moot point!
Vrg3: I understand you used the Select Monitor. I was asking if someone could check with an ODB scanner, like what the Referee would use. I doubt they have a select monitor.
But there's no such thing as a generic OBD-I scantool. Any third-party scantools that work with OBD-I Subarus are basically just Select Monitor emulators built by reverse engineering a Select Monitor.
like vrg3 said.....there is really no other type of obd1 scan tool.
IMO, you're worrying about the california/fed thing too much. They're not going to be able to tell.
ciper
Post by ciper »
Why do you guys say such thing? Generic scan tools show less information and display the other items in different ways. Ive used plenty of them to know this.
have you used one on a first gen legacy?? what other scan tools have you used, and on what cars/years?
Which ones have you used?
So-called "generic" OBD-I scantools are anything but. They actually implement many different scantools in one box. OBD-I is not a standard at all; it's just a retroactively-applied name (needed when they defined the OBD-II standard) to the first generation of onboard diagnostics used in cars.
I have an OBD-I scantool that is meant to handle all Asian cars made up through 1990. It comes with different cables for Subarus, Mazdas, Toyotas, etc. You tell it what kind of car you're hooking it up to when you turn it on. It then uses whatever proprietary protocol that manufacturer's factory scantools use, based on what they were able to reverse engineer. Since their reverse engineering skills are sometimes limited, they usually only manage to get a subset of the full scantool functionality.
I would highly doubt that the smog ref would be permitted to rely on readings from a device that uses reverse-engineered information and that Subaru does not certify as applicable to their cars.
In any case, you're really worrying about nothing. The Federal and California ECUs are the same. The listed part numbers don't differentiate.
ciper
Post by ciper »
"In any case, you're really worrying about nothing. The Federal and California ECUs are the same. The listed part numbers don't differentiate."
For the second and third sentences I agree.
For the first its not correct.
http://www.smogcheck.ca.gov/StdPage.asp ... n_1994.htm
California Certification
A federal Environmental Protection Agency (EPA) certified (federal or 49-state) engine cannot be used in a vehicle that was originally certified for California.
Dont misunderstand, I hope Im wrong! I have to be sure though.
