SCCA turbo restrictor
I am just Finishing up my 93 Legacy Turbo for SCCA Club rally and i wanted to know if anybody also rally's this car in the PGT class, and also what do you use for a restrictor?
Mike
02 WRX Sport Wagon -- For Sale--
2000 Impreza Wagon daily beater.
the restrictors i've seen for PGT are made of machined aluminum to the correct inside diameter, they were made with a flange on either end, one side bolted to the turbo inlet and the other to the rest of the intake. I believe they had welded an appropriate flange to the turbo housing for this to work, but i've also seen them made so that normal silicone couplings can be used
good luck... wouldn't mind seeing some more pics of the car
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
2000 Impreza 2.5RSC (Supercharged)
1990 Rover Mini 1000
2004 Forester XT
