I got my boost gauge mounted properly, finally. The OBX is history, the Auto Meter Phantom series gauge is in. I'm loving it, it turned out real nice. Here's some pics:
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
That looks good. I used the Z Series Autometer, only difference is the face is black instead of white.
I opted to put mine on the steering column, too, but in front of the tach. In the picture (linked below) it appears to block the upper range of rpm, but I had to take the picture at a low angle to fight the glare from the flash. It's placed quite well for my driving position.
ultrasonic wrote:I opted to put mine on the steering column, too, but in front of the tach. In the picture (linked below) it appears to block the upper range of rpm, but I had to take the picture at a low angle to fight the glare from the flash. It's placed quite well for my driving position.
Cool, I was thinking I might put my Phantom EGT there. It would be a mirror image of the BG but in the tac. I was planning to put it in the dash by the stereo but I think it would look good having double steering column gauges.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I'm thinking of getting plastic dash pods and plastic welding them into the column and partially embed them into the face (I can embed them since I have an aftermarket steering wheel that wouldn't interfere with reading the gauge).
BAC5.2 wrote:Matt - I think it would look like your steering column had Mickey Mouse ears.
Hahahaha, I think something popped I laughed so hard! I totally got the image in my head.
Ya, I was kinda unsure about the look too. I'll probably just stick with the aluminum face over the bottom pocket under the ash tray (no abs)for the EGT and the future A/F and oil temp. I think I'm going to mount them at an angle up towards the driver too. That'll look tight as hell don't ya think?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
evolutionmovement wrote:I'm thinking of getting plastic dash pods and plastic welding them into the column and partially embed them into the face (I can embed them since I have an aftermarket steering wheel that wouldn't interfere with reading the gauge).
That sounds pretty neat Steve! It would look sweet, if you can pull it off.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
If I can pull it off is right! The headlight and wiper stalks are close to the top, so that might make it a little more interesting, too. It'll still look a little Mickey Mouse head (I think I owe some royalties to Disney for saying that now) unless I also mount gauges around the lower perimeter the same way. I could probably fit one underneath on the left (right side has the horn).
Matt - Why an A/F gauge? Do you have the wideband installed? I'd just stick with the EGT and oil pressure.
Those two aren't as important, so you can have those down low looking up. I like all my gauges to be in good view, so I might get creative with fiberglass and plastic. Maybe some creative duct moving or something.
