Torquefreaks is having a $25 3 pull dynotune special on the weekend of Sept 17-18. But they only have fwd/rwd dyno. Can I pull "that" fuse and run the dyno on fwd only safely?
And where is that fuse located anyway.
Who else would be interested?
Portland Dyno Run anyone? Can I pull that fuse to do it FWD?
Just to clarify,
Why can't it be done?
A- it wont work period?
B- it would work but not safely?
All I know at this point is that I read somewhere on this board (I think) that you could pull a fuse and have FWD only. Please correct what incorrect knowledge I have.
A, it wont work period. Reason being, your center differential is mechanically operated, unlike a 4eat where it is electronically controlled by the TCU, or to be more specific Duty Solenoid C. Normally it is fuseless, however, when you insert a fuse in (i believe it's 10A or 15A) it will make Duty Solenoid C run at 100% duty. Applying no power to the rear wheels.
Ok, Now I understand, it is the automatics that this would kinda of work for, not the 5mt.
thanks
And DARN IT!
thanks
And DARN IT!
