Found some interesting stuff (opened my block)
TDGKORN
Post by TDGKORN »
The good news:
piston squirters are all still in.
pretty good shape for 200+k
The bad news:
#4 piston in bad shape
Image Image
#4 cylinder in bad shape
and the worst is the thrust bearing is completely destroyed
Troy
92 legacy ss 4eat
professor
Post by professor »
now you'll be forced to get the forged pistons you really wanted anyway
TDGKORN
Post by TDGKORN »
Forged pistons are overkill for what I want out of the engine.
300hp is all that I'm looking for. From the people that I have talked to the stock short block is plenty strong to do it.
I will be getting some different bearings though.
92 legacy ss 4eat
what bearings you getting?
TDGKORN
Post by TDGKORN »
I havn't decided yet, either cobb or crawford piston ones.
I just talked to http://www.ccrengines.com/ and they said that the reason the bearing was chewed up so bad was the fsm has a wrong torque spec for the crank pulley bolt. The fsm says 76lb/ft and they say 125lb/ft.
Anybody else ever heard of this?
92 legacy ss 4eat
boostjunkie
Post by boostjunkie »
Yeah, that problem has been discussed on this board before. A few people had the crank pulley come loose a little bit and chew up the key. But no one's actually taken apart the engine and noticed internal bearing damage because of this.
It makes sense, tho. Without the dampener properly fitted to the crank, there will be excessive force on the crankshaft bearings.
TDGKORN
Post by TDGKORN »
They said that 9 out of 10 times if the main bearings failed, it had been within 6-12 months of a timing belt change.
Makes you want to retorque your pulley bolt doesn't.
I know I will tonight.
92 legacy ss 4eat
THAWA
Post by THAWA »
Damn, maybe that's the cause of my failure. I did notice a wierd noise a couple nights after i finished the headgaskets but thought nothing of it because it only lasted a minute or so.
TDGKORN
Post by TDGKORN »
Yeah mine started making a strange noise a few days ago. Hopfully its not to late.
92 legacy ss 4eat
Matt Monson
Post by Matt Monson »
Get the Cobb bearings. Sorry to see it in such bad shape. Hopefully it isn't so far gone that you can't hone it out without overboring...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
TDGKORN
Post by TDGKORN »
I'm still looking for a machine shop that will even look at it. All the ones in my area are domestic only.
92 legacy ss 4eat
Maybe try a marine place. They have to do all kinds of engines.
TDGKORN
Post by TDGKORN »
I finally found a place that can do it but, I also found out that there are no oversized pistons available from subaru.
this post talks about it http://bbs.legacycentral.org/viewtopic.php?t=20735
There is a chance that I can hone the cylinders and take out the scuffing. If that works I can use a stock size piston.
I'm going to take some measurements tonight and hone the bore to see if its worth moving forword.
Troy
92 legacy ss 4eat
legacy92ej22t
Post by legacy92ej22t »
IIRC a set of custom forged piston are actually going to run you about the same price as new OEM ones. Food for thought.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
TDGKORN
Post by TDGKORN »
My two posts should probably be merged.
sorry :oops: :oops:
92 legacy ss 4eat
legacy92ej22t
I responded in your other thread. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I think Morgie paid like 130 for customs from cp pistons.
legacy92ej22t
Whaaa? I thought they were around $460 usd.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
TDGKORN
Post by TDGKORN »
really?
They just quoted me $575 for a set.
92 legacy ss 4eat
legacy92ej22t
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
TDGKORN
Post by TDGKORN »
That sounds a little more like what they quoted me.
92 legacy ss 4eat
morgie
Post by morgie »
I replyed to the other post ;)
135$USD is what i paid for the custom pistons, including pins, locks, rings.
be sure to mesure your worst cylinder before ordering your custom oversized pistons! And verify with your machineshop what oversize they prefer work with. (.20mm, .25mm.. )
morgie
'98 4Runner V6 Manual 4x4.
At first I was like, whaaaaaa?!! The I realized you were using metric examples for the oversizing.
morgie
Post by morgie »
oups yeah, i edited to include unit ;) ehe .20"Oversize, that's huge! haha
morgie
professor
Post by professor »
From the look of that scuffing, I don't think you have a chance of honing that out. It might look OK when you are done, but the eccentricity would be terrible compared to acceptable specs.
