Here's a little recap of the whole deal with pictures:
The struts, springs, and strut tops NEARLY bolt in. The bolts on the rear tops have a slightly different spacing. One solution is to put the correct tops in with spring perches that fit the STi springs. You can't use the existing STi perches because they are different, as shown in this picture:
I had planned on using my existing perches with the STi springs and group N rear tops for a GC, because I'd heard my perches would fit.
Turned out my perches were too big. I wasn't sure if perches that fit existed at the time, so I filed out the holes so that I could use the STi tops. Apparantly 90-91 tops will fit on the springs, as well.
It's a pretty ghetto way to go, but if you are very careful filing out the outer holes only as far as they need to go, you'll be pretty close to even and give the struts a little more camber in the negative direction. That's good, because the different geometry of the STi will cause slight positive camber when using the struts on a car without the wider GD sedan track.
I also put on an e-bay WRX rear strut tower brace, which I figured couldn't hurt. I suppose if I had the plates welded to the strut towers, it'd be even better.
The rest of the installation was pretty straight forward. I had the front struts changed in less than an hour, as they bolt in directly. One thing I'll note here is that 2005 STi front struts will not fit. The spindle changed for 05, so the flanges are wider apart, and so is the bolt spacing,
I really appreciated this tall boy at the end of the day. Thanks, Derek.
See how the cherry red strut lurks in the darkness:
Alas, I was defeated by the lateral links, and left them for another day:
A few weeks later, that day came. In the meantime, I installed these:
The driver's side was a pain, even after I took off the little skid plate dealie, and "moved" some power steering lines out of the way. Apparantly the way to do it is to loosen up the steering rack linkage. It's described on ravensblade-impreza mods.
Now, let's try to put on those lateral links. The 92-94 L model Legacies do not have a rear swaybar. So, the rear lateral links don't have the tabs for endlinks. The chassis does, however, have holes drilled to mount the swaybar brackets. To put on a rear swaybar, you can buy some of those expensive endlinks that attach to the hub, or find some used stuff on the cheap. I got some lateral links and endlinks for $30 from a 99 Impreza, swaybar mounting brackets from a WRX for about $15, and a rear 18mm turbo Legacy rear swaybar for $50.
This lateral link bolt didn't want to come off after a day of pounding, lubing, prying, and burning.
Lets try a sawzall:
HA HA! Suck on that. Uh, so, Santa Monica Subaru, you wouldn't happen to have that bolt would you? No? Okay, nevermind, I'll check at some other dealerships in the area.
Until then I'll just rock this grade 8 bolt I bought at home depot for awhile:
I tried to install the swaybar at this point, but the bolts did not want to thread into the old, rusty holes very well, even after I cleaned them out as best as I could, and as there was absolutely no space to exert any type of force on the bolt above the gas filler tube, I gave up, deciding to wait until I got the replacement toe adjusting cam bolt.
The bolt came, I installed it, and took a closer look at the swaybar bracket.
It looked like I could take off the plastic shroud on the tube, loosen everything up, and move it out of the way a bit. I also picked up a die and tap kit, to re-tap the threads in the frame. It worked beautifully, although I had to use a 6mm socket backwards with a hex wrench to turn the tap in the limited space.
The swaybar installation itself is pretty straight forward. You basically just feed it over the exhaust pipe and bolt everything down.
And with that, I have 04 STi take-off suspension, an 18mm turbo legacy rear sway bar, and polyurethane steering rack bushings. Coming next: new tires, an alignment, and [relatively] huge brakes.
Bonus shot:
